Doverdude Samba Member
Joined: September 29, 2015 Posts: 14 Location: Dover Foxcroft Me.
Posted: Tue May 22, 2018 6:33 am Post subject: Should I replace the water pump? |
I am putting in a new radiator and am also replacing all of the coolent hoses on the motor, should I replace the water pump while I'm at it? I have done the fuel lines. is there any other maintenance I should do while I am at it. also doing tuneup new belts and oil. thank you |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1030 Location: san diego
Posted: Tue May 22, 2018 6:46 am Post subject: Re: Should I replace the water pump? |
Is there play if you wriggle the pulley, if there's any sign of a leak, then yes, I would while you are in there, what year van, late are easier, if you have a pre 1986, and it looks unloved, you could be in for a headache, sized and broken bolts, early water pumps can be a nightmare.
When you refit, use antisieze, especially if you think you may have the van long enough to need to get in there again.
If you have a 1.9 and it looks fine, you might want to leave it alone. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Tue May 22, 2018 7:38 am Post subject: Re: Should I replace the water pump? |
it is a 90. Also do anyone sell a set of hose clamps for the motor coolent hoses? If not is there a list of the different clamps needed? |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
bettingonvans Samba Member
Posted: Tue May 22, 2018 8:58 am Post subject: Re: Should I replace the water pump? |
While your coolant is drained and you are working near your water pump anyway, replace your oil cooler seal.
I used constant-tension band type clamps from McMaster-Carr. It was helpful for me to look at this site to learn the hose diameters in order to know which clamps to buy. http://www.vanagonauts.com/files/VWtoNapaHoses.html
You may have already, but check your heater hoses and pipes. Mine looked to be about to blow which is why I started my cooling system project to begin with. _________________ 1990 Westfalia, GW2.2, Peloquins TBD |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Tue May 22, 2018 9:45 am Post subject: Re: Should I replace the water pump? |
if your water pump is of unknown age... I think you should replace it because the coolant is already out... and replace all the little hoses around the heat exchanger and the heat exchanger gasket too as suggested... |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed May 23, 2018 5:25 am Post subject: Re: Should I replace the water pump? |
And while you're there, hows the belts? Crank seal?
Sadly a simple repair/replacement ends up taking a week to fix everything you ran into. |
