Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Tue May 22, 2018 7:02 am Post subject: Removing plastic condensor plug from int dist. |
Oh it sounds easy--just change the condensor but for those of us with the plastic plug into the distributor type it becomes a head scratcher if we've never done it before--how do I get it out? Do I dig it out? Can I hit it from the top and not bust the distributor--do I use the palm of my hand on a screwdriver like it shows in a video but it's tighter than that so do I use a hammer instead? I noticed in a video I saw there was a cut in the scene where the guy was working at it then all of a sudden it was off lol
I just changed my condensor--I'd been noticing, reading here, that more and more modern condensors have been faulty so thought I'd ask what you pros do to get that plug out more directly, more assuredly for we who'd never done it before because it is an easy fix for what seems likea more common problem.
We did a combination push down from the top with a screwdriver, pull down with plyers--it was really in there! Not that you'd ever use it again I'm going to guess they all look pretty mangled after they come out.
After removal
_________________ 1969 Beetle
Stock 1500 |
mukluk Samba Member
Posted: Tue May 22, 2018 12:38 pm Post subject: Re: Removing plastic condensor plug from int dist. |
Not that it helps a whole lot, but I've never had a problem either pushing them out with a common screwdriver with the tip offset near the edge, or using needle nose pliers to push them out while giving a bit of a twist. _________________ 1960 Ragtop w/Semaphores "Inga" |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue May 22, 2018 12:41 pm Post subject: Re: Removing plastic condensor plug from int dist. |
Looks like you have a 205K/L/M with the condenser pressed into the bottom. To remove just use a screwdriver and push it out. To install they make a tool to press it in and not damage the wires.
_________________ Glenn
Member #1009
#BlueSquare |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue May 22, 2018 3:51 pm Post subject: Re: Removing plastic condensor plug from int dist. |
you can make your own tool from a valve guide like this (from the gallery)
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Tue May 22, 2018 5:15 pm Post subject: Re: Removing plastic condensor plug from int dist. |
60ragtop wrote: |
That's the exact tool I have! Made it myself after my first valve job as a newbie! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
