bent front beam?
vwboat
vwboat is offline
PostPosted: Tue May 22, 2018 7:04 am    Post subject: bent front beam? Reply with quote
Ran off the road in the dark and hit a small tree. after pulling myself back on the road noticed that the car wanted to pull to the left. Next morning I check car and can not see any thing bent or even appear to be hit or bent,
How do I check if my beam is bent? Thanks for any help/info.
dustymojave
dustymojave is offline
PostPosted: Tue May 22, 2018 12:29 pm    Post subject: Re: bent front beam? Reply with quote
You would need to unbolt the beam and put a straightedge across the back of it. You may have bent trailing arms also. Those are harder to measure. Another thing to check for bent is tie rods. Damage is more visible for these. You may also bend a steering arm on a spindle. Or even the spindle shaft.
It seems you need to take it to an alignment shop that is familiar with beam front ends on old school VWs. Lots of people working at alignment shops these days have NO CLUE about such front suspension.
Richard
SoCalBajas Member
earthquake
earthquake is offline
PostPosted: Thu May 24, 2018 10:22 am    Post subject: Re: bent front beam? Reply with quote
The driver side lower tube on my front beam is bent a bit, I must have nailed a big rock at one point. Its bent back about 1/4" from the stock front mount, I am going to try to straighten it out with a piece of chain and a bottle jack one of these days, I have too much work in it just to toss it out.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
dustymojave
PostPosted: Thu May 24, 2018 3:24 pm    Post subject: Re: bent front beam? Reply with quote
As long as the tube is not kinked, that will work.
Richard
SoCalBajas Member
vwboat
vwboat is offline
PostPosted: Fri May 25, 2018 4:00 pm    Post subject: Re: bent front beam? Reply with quote
Thanks for the reply's Trusted alignment shop confirmed beam and trailing arms bent. Have found good buy on two used beams. Have to check them out but got for a very very small amount.
Thanks again for the reply's and help.
