nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Posted: Tue May 22, 2018 5:15 pm Post subject: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
This was weird, but I have some ideas what happen. Just guessing, ya sometimes cable stretch but not all at once and leave an 1" to tighten.
Thought, as I have seen cables cut through sheet metal and I guess can a more direct route.
Another is maybe the tube in the tunnel lost a spot weld and got free. If it did it would not be like the clutch cable tube which can keep you from driving the car, been there, happened to me. The cable will be ok to if some are still holding.
It is pouring rain so could not do a better inspection but the car runs fine.
Got any ideas. Oh also checked the dual carb linkage, all ok. ???? _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
KTPhil Samba Member
Posted: Tue May 22, 2018 5:54 pm Post subject: Re: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
If cast poorly, the ferrule or fitting at either end can pull loose from the cable itself, too.
I would suspect linkage or clamps first, then all the other stuff.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Wed May 23, 2018 6:04 am Post subject: Re: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
Sometimes, the fitting of the cable sheath is tight at the rear ferrule, where it attaches to the hard metal line in the tunnel..
You have to reach up to the front of the throttle cable sheath,
Fish your fingers thru the little 2-tube oval-shaped throttle/clutch cable tube exit grommet,
And force the little ferrule down over the throttle cable tube.
If you didn't do this step,
(and many don't, it's hidden by the little 2-tube oval grommet thingie.
way up in a dark dirty place at the front of the trans),
The cable sheath might be butting up against the end of the hard cable tube,
Instead of seating aound it.
It ran like that for you a while,
Then you hit a bump or something,
and it allowed the cable sheath to finally seat clear home on the end of the hard line.
Now you got some more cable..
That's my theory... Take it FWIW.. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed May 23, 2018 6:43 am Post subject: Re: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
Clatter sounds extremely possible seeing this is a 914 T-4 conversion and what you said could have happened. The Gen/s Alt stand controls the height of the fanhousing, so the angle could have been off for a long time..
Crazy how when you think of how simple it seems as just a simple cable connected on each, but look at all the variables we found already. _________________ email: [email protected]
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu May 24, 2018 6:50 am Post subject: Re: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
nextgen wrote: |
OK So after tightening the cable after it pulled off the amazing growing an Inch trick, I get in the bug drive up and down mountain roads and the car runs great, so we may never find out what made it grow that inch. |
I think a good looking female VW was nearby !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu May 24, 2018 9:02 pm Post subject: Re: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
Do you distinctly remember reaching up above the front trans mount,
And seating the throttle cable sheath around the hard line in the tunnel??
Unless you take and force it into place,
It won't seat home.
At least with the throttle cables I have been finding for the last 15 years or so.. _________________ Bus Motor Build
Posted: Sat May 26, 2018 8:13 pm Post subject: Re: Suddenly gas pedal feels like cable broke -tighten cable 1" OK |
Clatter that cable has been in that position over 15 years........... after what you said , made me think about something I did that may have fixed the problem with out me realizing it.
After saw the slack in the cable I pulled it out of the pedal and took a vice grip to it to make the end square so it could not slip out. Not thinking because it was not square was way it may have slipped put of the pedal a bit.. I went back to loose it then squared it. The tighten it. After 15 or more years the end got out of shape. That metal is extremely tough. Had a hard time bending it, but constant on and off the pedal for over 15 years can slowly move it.
Most logical as of yet.. _________________ email: [email protected]
