The Beatles beetle Samba Member
Posted: Wed May 23, 2018 7:43 am Post subject: VIN number door jamb sticker removal |
Can anybody tell me how can I remove the VIN sticker on the door jamb without breaking it? Do I need a special tool? Is it even possible? |
Brian Samba Moderator
Posted: Wed May 23, 2018 9:47 am Post subject: Re: VIN number door jamb sticker removal |
Yea, you should be able to use a dremel with a cutoff wheel. Just cut the metal around the sticker, being careful to not hit the sticker. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Beeble1 Samba Member
Joined: August 14, 2012 Posts: 578 Location: Manteno, Illinois
Posted: Wed May 23, 2018 2:35 pm Post subject: Re: VIN number door jamb sticker removal |
Your best bet is to remove it and get a reproduction sticker.
https://www.thesamba.com/vw/classifieds/detail.php?id=2051377 _________________ Beeble1, ‘73 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, ‘13 Beetle 2.5L Daily Driver
Dealership items from Bishop-Wayne Volkswagen & Turner Volkswagen in Kankakee, IL wanted |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Wed May 23, 2018 4:27 pm Post subject: Re: VIN number door jamb sticker removal |
Brian wrote: |
Yea, you should be able to use a dremel with a cutoff wheel. Just cut the metal around the sticker, being careful to not hit the sticker. |
This is Brian's joke ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
vwoldbug Samba Member
Posted: Wed May 23, 2018 5:00 pm Post subject: Re: VIN number door jamb sticker removal |
It's made to break up . Maybe ask the highway patrol . |
Posted: Thu May 24, 2018 7:40 am Post subject: Re: VIN number door jamb sticker removal |
Can I heat up the glue? Or will that damage the sticker? |
Zundfolge1432 Samba Member
Posted: Thu May 24, 2018 7:43 am Post subject: Re: VIN number door jamb sticker removal |
The Beatles beetle wrote: |
Sorry Ringo it’s a tamperproof sticker designed to come off in pieces if you try to remove it. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu May 24, 2018 7:44 am Post subject: Re: VIN number door jamb sticker removal |
The sticker is designed to be impossible to peel off and re use on purpose, either tape it off or get a fresh one, there's no way that one will come off in one peice and ever be a sticker again. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 24, 2018 7:46 am Post subject: Re: VIN number door jamb sticker removal |
If i want to keep the OG sticker, i have to cut the metal around it? |
EDTucker Samba Member
Joined: August 25, 2016 Posts: 12 Location: Alameda, CA
It is an anti tamper sticker so any peeling or scraping will just cause it to break apart due to the circular pattern. Heating will just distort it an it will turn brown. It’s really not worth your time to try and peel it the link mentioned above is your best bet. If you want the original get high quality painters tape and a exacto knife and tape it off I deal with similar tape for SOLAS year at work it a pain to remove and always breaks apart. |
bluebus86 Banned
Posted: Thu May 24, 2018 9:25 am Post subject: Re: VIN number door jamb sticker removal |
for ultimate originality, keep the sticker attached, as repro stickers are almost always not exact in every detail. if you paint around a masked sticker, the new paint will be raised up in thickness around the sticker, a sign that the cars has been repainted. so mask the sticker and carefully detail hand sand the original paint around it down a layer or so. taper the sanded area away from the sticker, then repaint. As you have already reduced the original paint thickness around the sticker, the new paint layer will come up to the correct height relative to the sticker. its tricky, you may need to do some fine detail color sanding of the new paint to remove any ridge of paint caused by masking tape edge, but you will be rewarded with an original sticker with original look paint around it.
Good Luck, Stick To It, and Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Thu May 24, 2018 2:54 pm Post subject: Re: VIN number door jamb sticker removal |
cutting around the sticker was a joke....and technically repop vin stickers are illegal....otherwise anyone could steal a car and put a new sticker on it |
AlmostHeavenWV_VW Samba Member
Posted: Thu May 24, 2018 3:49 pm Post subject: Re: VIN number door jamb sticker removal |
Put down the heat gun.
Put down the cut off wheel.
It is illegal to tamper, alter, or otherwise mess with identifying number plates, stickers, stamping.
Leave the sticker be. If you are going to paint, use good quality masking tape and a steady hand.
Otherwise, don't touch it or mess with it. It's the law, man.
https://www.law.cornell.edu/uscode/text/18/511 _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu May 24, 2018 4:20 pm Post subject: Re: VIN number door jamb sticker removal |
Read b,2,b.
Not ilegal to remove it destroy if it's necessary as part of the repair. However, a copy VIN tag would certainly be illegal.
If you want to keep it original, mask it off for paint. If your trying to put it on another car.. |
