Anyone near The Algarve Portugal? Help me please
t-hardwick
t-hardwick is offline
PostPosted: Wed May 23, 2018 7:59 am    Post subject: Anyone near The Algarve Portugal? Help me please Reply with quote
Hi, I'm stranded at a campsite with my vw bus, drove from England to Italy thru France all the way to Portugal without a hiccup. In terms of describing - it starts up fine, idles fine and revs really well (you'd think it is running perfectly). 1st pull away and it will be smooth and almost normal (very slight hesitation through acceleration) and then after 500mtrs it will bog down fully, hesitate and will struggle to get above 40mph (even down hill). If my foot lightly rests on the pedal it will run smoother (but won't pick up speed) then if I put my foot down. The longer I drive it, the worse it gets.
What I have done
Plugs
Cap
Rotor
Leads
Fuel filter
Rebuilt carbs
Checked pump
Changed coil
I have a 2.0 with twin kadrons
If the vans a 'rockin' dont come a 'knockin'
If you pay peanuts, then you're going to get monkeys'
1975 Beetle
TomWesty
TomWesty is offline
PostPosted: Wed May 23, 2018 8:29 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Sounds like fuel starvation. Change the fuel filter again. Depending on the brand of filter and condition of your tank, they can plug up fast.
busdaddy
busdaddy is offline
PostPosted: Wed May 23, 2018 8:41 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Is this your 75 Beetle we are discussing?, or some sort of bus?, if so what year?
aeromech
aeromech is offline
PostPosted: Wed May 23, 2018 8:49 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Try it with the gas cap off
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
RalphWiggam
RalphWiggam is offline
PostPosted: Wed May 23, 2018 8:58 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Could be fuel starved from the screen in the tank. Or a vacuum leak.
t-hardwick
PostPosted: Wed May 23, 2018 9:19 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
It's a bus with a pancake 2.0 1980
1975 Beetle
Tcash
Tcash is offline
PostPosted: Wed May 23, 2018 9:52 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
If you did not get a bath in gas, when u pulled the fuel hose off from the gas tank to the filter. Your gas tank is plugged.
rsbadura
rsbadura is offline
PostPosted: Wed May 23, 2018 9:56 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
if you're searching for local contacts and help, try this: http://www.airmapp.com/mapp
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupé (Type 14)
1979 VW luxury bus to camper conversion (Type 22, T2b)
1982 Eriba Pan camping caravan
2017 VW Cross Polo (Type 6C)
t-hardwick
PostPosted: Wed May 23, 2018 11:19 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Tried no gas cap, didn't fix
Sprayed easy start all over for leaks , nothing
When I pulled the line off to change the filter lots of gas came out.
I have 40L in there currently but tomorrow I will drain out and check that filter.
I do think you're right on the starvation side but would any electrical faults cause this also? Or something deeper in the engine?
Thanks everyone.
1975 Beetle
timvw7476
timvw7476 is offline
PostPosted: Wed May 23, 2018 11:27 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
if the filter flows OK, then it's the wiring to your fuel pump, or the pump
itself can't deliver....I know there's a spec for the fuel injection pump, as
far as cc's per 20 or 30 seconds, I would think your pump is failing to deliver
if the fuel flows freely from the tank & filter isn't plugged up.
Would not start digging 'deeper in the engine' yet.
t-hardwick
PostPosted: Wed May 23, 2018 11:35 am    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Here is a video clip of what's going on.
Also will my tank have an in tank filter screen?
https://youtu.be/GU1CSU-lWWw
1975 Beetle
1970fun
1970fun is offline
PostPosted: Wed May 23, 2018 1:11 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Defenitly fuel starvation, you can hear it puffing trough the carbs a typical sound for not enough gas in the carb bowl, could be the fuel pump, a clogged fuel line or dirty blocked jets?
aeromech
aeromech is offline
PostPosted: Wed May 23, 2018 1:24 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
I found a rag inside a tank once acting similarly
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
t-hardwick
PostPosted: Wed May 23, 2018 1:30 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Literally cleaned every part of it. Loads of fuel in the bowls. Jets are clear as are all the carb pipes etc.
Also brand new tank was fitted 6months ago.
1975 Beetle
SGKent Premium Member
SGKent is offline
PostPosted: Wed May 23, 2018 1:38 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Does the engine have a catalytic converter on it?
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
t-hardwick
PostPosted: Wed May 23, 2018 2:03 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
No cat converter. The spout on the tank is not removable. Is there still a screen inside the tank?
1975 Beetle
SGKent is offline
PostPosted: Wed May 23, 2018 2:23 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
no.
Electronic ignition or points?
1971 (sold)
1977
aeromech
aeromech is offline
PostPosted: Wed May 23, 2018 2:24 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
If the bowls are full you can rule out tank or pump.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
t-hardwick
PostPosted: Wed May 23, 2018 3:19 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
Ok, let's say that the fuel system is ok and it is an ignition fault. I have replaced all the leads, plugs, cap and rotor (the original rotor was melted at the end). Perhaps the hall sender? Measuring the voltage at the coil I get nearly 12v.
The hall sender plug reads at 10.81v where I plug it into my distributor. So I am losing 1v somewhere. Could this cause a problem? In terms of other ignition perhaps the timing or vacuum advance is at fault? I'm on a campsite in Portugal with no 'specialist' tools so hard to check timing etc. Cheers
1975 Beetle
t-hardwick
PostPosted: Wed May 23, 2018 3:21 pm    Post subject: Re: Anyone near The Algarve Portugal? Help me please Reply with quote
SGKent wrote:
no.
Electronic ignition
1975 Beetle
