SGKent Samba Member
Posted: Wed May 23, 2018 3:30 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
do a cylinder balance test to see if one cylinder drops RPM less than the others and is weaker. Also in the dark look at the engine and plug wires, cap etc., see if any show signs of sparks in the dark where a wire might be arcing to ground. Watch the belt etc., not to touch it in the dark. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed May 23, 2018 3:42 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Solid or hydraulic lifters? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
t-hardwick Samba Member
Joined: December 13, 2009 Posts: 108 Location: Kelowna BC, Canada
Posted: Wed May 23, 2018 4:10 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
aeromech wrote: |
Solid or hydraulic lifters? |
Hydraulic _________________ If the vans a 'rockin' dont come a 'knockin'
If you pay peanuts, then you're going to get monkeys'
1975 Beetle |
Target Samba Member
Joined: August 09, 2017 Posts: 60 Location: Los Angeles
Posted: Wed May 23, 2018 4:14 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
I've had issues with electronic ignition in other vintage non-VWs. If you really can't pinpoint the issue and it seems like it's electrical, Coils can be super finicky and electronic ignition can just crap out without notice. These things don't slowly go bad. It'll be fine and then unreconcilable problems. |
Tcash Samba Member
Posted: Wed May 23, 2018 5:42 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Next time it dies.
Cranks Won't Start Test |
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Wed May 23, 2018 6:19 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
I recently did work on a 63 F100 that had a pertronix kit. It had very similar symptoms for fuel starvation. I pulled the carb and it was full. Cleaned it anyway. Problem was still there. Everything was working. Ended up being a bad pertronix kit. |
danfromsyr Samba Member
Posted: Thu May 24, 2018 6:44 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
the vanagon fuel tank certainly does/should have an internal screen.
https://www.thesamba.com/vw/forum/viewtopic.php?t=533878
also the plastic hose internal to the fuel supply can split and suck air when low..
not usually a problem with a new tank, or with 40l.
I did once have a cheap aftermarket replacement tank that would starve on turns when it still had a few gallons of gas..
t-hardwick wrote: |
SGKent wrote: |
Does the engine have a catalytic converter on it? |
No cat converter. The spout on the tank is not removable. Is there still a screen inside the tank? |
davideric9 wrote: |
Just for the record I was having trouble with my van (2wd 1987) running well and it would sputter out and try to die. I would pull over and then it would seem fine and I drove it to work and home again. It did the same thing the next day, pull over near the house as it lost power, waited a few moments and then was able to drive to work with no problem, until I had to have it towed home when if wouldn't stay started.
I decided that the tank was the problem after replacing many parts. It ran great after the tank was replaced, so to be sure I really had this solved I needed to look inside the tank to see the problem, and I found it. The supply hose was no longer securely attached to the tank, so at half a tank the pump was sucking more air than fuel as the pump was not sucking fuel from the bottom of the sump.
Tank cut open with sawzall
filters at the center of the tank, in case you were wondering
The supply hose as I found it no longer making a seal to the hose (not great focus)
and to show it up close and pulled apart
Abscate wrote: |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Thu May 24, 2018 6:59 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
I had some thing similar on my 78 Bus. I pulled these pieces of rubber filler neck out of the bottom of the tank.
_________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
SGKent Samba Member
Posted: Fri May 25, 2018 10:32 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Did you find the cause? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri May 25, 2018 12:05 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
SGKent wrote: |
Did you find the cause? |
I have found this when checking one of the carbs. Not sure if this would cause my problem. I have also been in contact with Alex from the samba who is really nice bloke and helping me out with a spare carb he has. Going to try it tomorrow and see how I fair.
Do you think from the pic that would be at fault?
Thanks for all the advice and help. _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
SGKent Samba Member
Posted: Fri May 25, 2018 5:20 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
missing accelerator pump nozzle? Yes, especially if it is stuffed between a valve and seat, or it mangled a spark plug. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Fri May 25, 2018 6:45 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
The "buy a Bus, drive it around Europe, then ship it back home" dream was much more charming when the Bus was actually new. My mother did it with an Oval Beetle. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51157 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 25, 2018 7:01 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
That's one odd looking Kadron _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 25, 2018 7:17 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Not a Kadron, when I went out back to look at my old Solexes, I didn't want to disturb the black snake that was guarding them. _________________ I know the pieces fit, cos I watched them fall away.
Posted: Fri May 25, 2018 10:13 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Volswagon wrote: |
The "buy a Bus, drive it around Europe, then ship it back home" dream was much more charming when the Bus was actually new. My mother did it with an Oval Beetle. |
It’s my brothers bus. He’s only on mobile so I’m doing the speaking for him. I thought they were kadrons but they’re solex I forgot to edit that. _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri May 25, 2018 10:19 pm Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Did you check for vacuum leaks yet? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sat May 26, 2018 11:16 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Good morning everyone.
Update: after meeting with Alex from the samba he has provided me with a replacement solex and now I am back on the road running great. Thanks everyone for your input and advice. If I hadn’t relied directly too you all your suggestions were noted and checked.
Feels great to be back on the road.
Cheers. _________________ If the vans a 'rockin' dont come a 'knockin'
1975 Beetle |
Posted: Sat May 26, 2018 11:20 am Post subject: Re: Anyone near The Algarve Portugal? Help me please |
Another samba success story _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
