guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Wed May 23, 2018 6:34 pm Post subject: Bay Window instrument panel gasket |
I removed my dash as part of my rewiring project
there is a thin plastic gasket like ring around the dash mine is broken into about 9 pieces. Is there a replacement for that?
I was thinking maybe some thin double sided foam tape.
any suggestions
Thank you
_________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
SGKent Samba Member
Posted: Wed May 23, 2018 6:49 pm Post subject: Re: bay instrument panel gasket |
either thin rubber hose cut with a slit or contact Ken at TheBusco. It took me awhile to find it and it is kinda like split hose. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
vwmerckx Samba Member
Joined: August 12, 2012 Posts: 195 Location: Phoenix, AZ
Posted: Wed May 23, 2018 7:07 pm Post subject: Re: bay instrument panel gasket |
This may be what you are looking for??
https://busok.nl/afdichting-tellerunit-t2-top.html
I have ordered from BusOK from the Netherlands for my '71 Tintop Westphalia and have pleased |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed May 23, 2018 7:26 pm Post subject: Re: bay instrument panel gasket |
It’s amazing that it might be available. I never would have guessed. That said, as opposed to ordering from the Netherlands, I think I’d try and find a substitute like has been already mentioned. Either foam strip or some kind of hose you can split with a razor. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Angus II Samba Member
Joined: June 01, 2016 Posts: 708 Location: Mammoth Lakes Ca. 93546
Posted: Wed May 23, 2018 8:31 pm Post subject: Re: Bay Window instrument panel gasket |
Hello,
Well, if you must have it... without paying for it...
I would think, that maybe looking at auto upholstery seat welting, it will work.
If you relieve cut the corners, and maybe use some heat too hold the form. It would be a much cleaner look than just a piece of split tubing...
Yet, it's your bus...
It's the little things that matter... |
Posted: Thu May 24, 2018 1:05 pm Post subject: Re: Bay Window instrument panel gasket |
what does it do??
do I need it _________________ 69 doublecab with 2" lift
Suzuki DR650
airschooled Air-Schooled
Posted: Thu May 24, 2018 1:23 pm Post subject: Re: Bay Window instrument panel gasket |
guzzirider wrote: |
what does it do??
do I need it |
After mine evacuated itself, I noticed a SLIGHT rattle of the instrument cluster over railroad tracks and potholes. Of all the extinguishable rattles in a Volkswagen, it’s mid-grade annoying. Not as bad as a slacked and loose window regulator, but worse than a westy bed bracket rattle.
www.airschooled.com |
