Francoc Samba Member
Posted: Thu May 24, 2018 9:34 am Post subject: Oil filter stuck |
The oil filter that’s currently on won’t move. I have a filter wrench, the kind that’s basically a dish to match the faces on the filter. When I turn the wrench, if I apply enough force, it skips but the son of a b**** filter won’t turn. Any suggestions? Thanks in advance. |
SGKent Samba Member
Posted: Thu May 24, 2018 9:38 am Post subject: Re: Oil filter stuck |
square bladed screwdriver with a pan under it to catch the oil that will leak. Stick the screwdriver thru the middle of it and use it as a lever.. Or get an old leather belt and wrap it around the filter, use a pair of vice grips to grab and turn like an oil strap wrench - which will also work quite well. I keep a couple of them around for moments like you are having. You can also hit the base with a chisel and hammer. That method will destroy the mount if you slip or are not careful. We used to have to unspin the fiat 124 spider and coupe filters from above with a long screwdriver that way. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu May 24, 2018 10:40 am Post subject: Re: Oil filter stuck |
Have you tried a higher quality filter wrench, they are much more sturdier than the junky stuff you get from Wally World.
Yes you may have to do the screwdriver method that SG Kent mentions, not desirable to do, but sometimes necessary.
Filters don't need to be all that super tight either, most will specify how far to turn them past contact. 3/4 of a turn is typical.
If you don't travel off road and don't have a lowered bus, then next time use a Motorcraft FL-1a filter or equivalent, it is a bit longer and makes removal easier. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu May 24, 2018 12:40 pm Post subject: Re: Oil filter stuck |
-are you trying to turn it the proper direction?
-get a big pair of channel-lock pliers to turn it (that's how i've done it since i can't evern remember how long, and it's been even longer since i've owned a "true" oil filter wrench). you're not trying to save it, so it really doesn't matter if you dent/crimp the bottom of the filter while removing it. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu May 24, 2018 12:44 pm Post subject: Re: Oil filter stuck |
hazetguy wrote: |
Righty-tighty Leftie-loosie; Upside downy turn arouny? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
timvw7476 Samba Member
Posted: Thu May 24, 2018 1:00 pm Post subject: Re: Oil filter stuck |
all for puncturing it, but there was a steel oil filter wrench that was sold
a decade ago (seems they are all hard plastic with a partial claw these days)
this older wrench came with a continuous steel strap, so it fully wrapped
around the filter body, so more tug equaled more bite on the body, I loved
it to death, ended up tweaking the joint where the handle met the strap.
but it worked where other filter wrenches slipped/ failed. |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2536 Location: Plattsburgh, New York
Posted: Thu May 24, 2018 3:45 pm Post subject: Re: Oil filter stuck |
asiab3 wrote: |
hazetguy wrote: |
Righty-tighty Leftie-loosie; Upside downy turn arouny? |
That still gets me sometimes... |
Posted: Thu May 24, 2018 5:12 pm Post subject: Re: Oil filter stuck |
Below is a picture of my DIY solution: drill two holes on the side of the dish. Put the dish against the filter. Drill two small holes on the filter. Wait for gallons of oil to pour out, even though the engine has already been emptied. Screw in two small screws. Turn dish with wrench without it slipping. Win.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51127 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu May 24, 2018 5:41 pm Post subject: Re: Oil filter stuck |
Francoc wrote: |
Krafty and elegant, nice work! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Thu May 24, 2018 7:30 pm Post subject: Re: Oil filter stuck |
What's elegant about the F-word on the filter? Finger tight means just that. Any more potentially damages the filter parts, constricting the bypass circuit.
Have used the screwdriver method in a jam. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Tcash Samba Member
Posted: Thu May 24, 2018 8:01 pm Post subject: Re: Oil filter stuck |
First time I seen that one, that'll work.
punch a hole in the bottom of the filter and drain it first, that way it won't be so messy. |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Thu May 24, 2018 8:20 pm Post subject: Re: Oil filter stuck |
asiab3 wrote: |
Hands down best post all day! Thanks for the chuckle. _________________ 77 Westy - Cape Cod Sage
LLAP |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Thu May 24, 2018 8:39 pm Post subject: Re: Oil filter stuck |
And steer clear of Fram filters. 100% pure crap. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
SGKent Samba Member
Posted: Thu May 24, 2018 9:37 pm Post subject: Re: Oil filter stuck |
I tired to find an oil filter video as a gag but everyone of them was 5 minutes or more. Off to bed, good night. BTW, anyone know how to care for a sick alligator lizard the dog tossed around? The vet was out and everyone else said let it die. Can't do that. I'll probably dream Godzilla is chasing me now and the Alligator Lizard that I was nice to drives up in my VW bus and rescues me before Godzilla tries to kill me.
Use a screwdriver next time. If not then use 3 screws to get the best bite in case one breaks. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Thu May 24, 2018 9:40 pm Post subject: Re: Oil filter stuck |
My Mom used to pay me 10 cents for every lizard I shot with my BB gun. Made enough to pay my way through college. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri May 25, 2018 6:14 am Post subject: Re: Oil filter stuck |
SGKent wrote: |
...anyone know how to care for a sick alligator lizard the dog tossed around? The vet was out and everyone else said let it die. Can't do that. I'll probably dream Godzilla is chasing me now and the Alligator Lizard that I was nice to drives up in my VW bus and rescues me before Godzilla tries to kill me. |
Have you been to the desert in a Bus with no name? With alligator lizards in the air, seasons crying, and such? _________________ I know the pieces fit, cos I watched them fall away.
Posted: Fri May 25, 2018 6:22 am Post subject: Re: Oil filter stuck |
Francoc wrote: |
Below is a picture of my DIY solution: drill two holes on the side of the dish. Put the dish against the filter. Drill two small holes on the filter. Wait for gallons of oil to pour out, even though the engine has already been emptied. Screw in two small screws. Turn dish with wrench without it slipping. Win. |
interesting concept, but a big channel-lock would have had the filter loosened before you were finished drilling the first hole in that filter socket tool thing. and with a lot less mess. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
SGKent Samba Member
Posted: Fri May 25, 2018 6:44 am Post subject: Re: Oil filter stuck |
Volswagon wrote: |
SGKent wrote: |
Have you been to the desert in a Bus with no name? With alligator lizards in the air, seasons crying, and such? |
yes - it was a 1971 bay and it gave me an easy peaceful feeling. Broke down once and oh my lord it was a girl in a flatbed who slowed to help.
Channel locks would have done the job in 15 seconds. I keep one of these around for that type event too - there are many different styles and some use a ratchet so they work in a confined space. While drilling two holes was creative, to me it is overkill like preheating eggs in six stages before boiling them. Glad it worked out.
Posted: Fri May 25, 2018 8:01 am Post subject: Re: Oil filter stuck |
The tool in the post above mine is available with a pivoting handle so it can angle down and spare your knuckles a high-speed visit into the fan shroud.
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri May 25, 2018 8:13 am Post subject: Re: Oil filter stuck |
SGKent wrote: |
yes - it was a 1971 bay and it gave me an easy peaceful feeling. Broke down once and oh my lord it was a girl in a flatbed who slowed to help. |
Too bad it was a Ford. But it's hard to find words that rhyme with Volkswagen. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
