sandhopper Samba Member
Joined: December 13, 2004 Posts: 453 Location: Norwalk Ca
Posted: Thu May 24, 2018 12:17 pm Post subject: Powerglide trans with vw starter |
Any one have pictures or kit to install a vw starter to a PG trans ?
Looking to put the starter on the bellhousing side so I can run all the vw cooling tins
Thinking about a bus bellhousing and cutting off the bell on the trans , will this work has anyone done this ?
If you have a trans with this done I might buy it even if just the case that can be rebuilt |
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 256 Location: Peoria, Illinois
Posted: Thu May 24, 2018 1:21 pm Post subject: Re: Powerglide trans with vw starter |
Marty Staggs or maybe it was Skaggs had a race care with VW engine in front and powerglide and conventional differential. He used to have a web sight where he sold turbo stuff. You can try a Google search for him. He might be able to advise you as how to go about it. |
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Thu May 24, 2018 1:32 pm Post subject: Re: Powerglide trans with vw starter |
Probably going to need some type of adapter plate like 1/4 aluminum between motor and trans. |
Posted: Thu May 24, 2018 1:56 pm Post subject: Re: Powerglide trans with vw starter |
Ye I will need the plate that goes between engine and trans , I have found that part
I got a flywheel adapter from Marty
Looking for away to mount starter |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu May 24, 2018 2:08 pm Post subject: Re: Powerglide trans with vw starter |
I think unless you go direct drive you are not going to be able to run a torque converter.
what is the application of this motor/trans, race car, street car? _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Thu May 24, 2018 5:05 pm Post subject: Re: Powerglide trans with vw starter |
I don't know if you can use a VW starter on a GM flex plate. Do the gears mesh?
My VW dragster is VW engine with a powerglide. It uses a reverse rotation Chevy starter mounted on the bell housing. Custom fab work to the bell housing to mount the starter there. Not overly elaborate though _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Posted: Fri May 25, 2018 8:33 am Post subject: Re: Powerglide trans with vw starter |
Eaallred wrote: |
My VW dragster is VW engine with a powerglide. It uses a reverse rotation Chevy starter mounted on the bell housing. Custom fab work to the bell housing to mount the starter there. Not overly elaborate though |
I would like to see some pictures of your BH with the mod done , even some measurements will help .
I think you can change the gears on the VW hi torque starter to match the chevy flex plate |
Posted: Fri May 25, 2018 5:01 pm Post subject: Re: Powerglide trans with vw starter |
I picked up a core aluminum PG today so fun should begin soon
Really need some pictures or measurements of one that has been done
First step is to get this thing clean |
Ebel Samba Member
Posted: Fri May 25, 2018 7:11 pm Post subject: Re: Powerglide trans with vw starter |
I don't know if its needed but some information on how to reverse direction of a starter can be found on robotics websites where they use starters as forward reverse motors. Involved messing with the coils but just the hook up points. |
Posted: Mon May 28, 2018 9:03 am Post subject: Re: Powerglide trans with vw starter |
Trans all cleaned up , can't seam to find info on how to add the starter pocket anywhere . any info pictures , web sites , shops that do this I need help
Thanks |
