Joined: June 05, 2013 Posts: 4 Location: Northridge, Ca
Posted: Thu May 24, 2018 1:14 pm Post subject: Raising My Ghia's Rear Suspension |
I have a late 72 Conv Ghia and I want to raise the suspension. What's the best way to do that and do I need to lower the front suspension to give the car that "stacked" look? This is how the car looks now but I want it just the opposite. Thanks
Last edited by [email protected] on Sat May 26, 2018 3:11 pm; edited 1 time in total |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Thu May 24, 2018 1:20 pm Post subject: Re: Raising My Ghia's Rear Suspension |
Take the engine out, that'll raise the rear right on up. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
c21darrel Samba Member
Posted: Thu May 24, 2018 2:52 pm Post subject: Re: Raising My Ghia's Rear Suspension |
An outer click will be too much, unless you want to be like that goofy bastard that tried going for the rally look. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Fri May 25, 2018 7:04 pm Post subject: Re: Raising My Ghia's Rear Suspension |
I just finished reindexing the rear of my 70. IRS just like yours. You don’t say how much you want to raise it. You may have to grind off the trailing arm stops, get longer shocks etc.
I drew out a pattern and at a 16” pivot point 4.5 degrees results in about an inch change. Stock height is about 21 degrees on an unloaded spring plate. Don’t worry about how many clicks inner or outer as in my case each had to be adjusted. Just get a magnetic angle finder and extrapolate.
In my case I just wanted the rear a tad lower so I went with 18 degrees which should give me about a 3/4 inch drop.
My drivers side was resting at 20 degrees and my passenger side was resting at 21. Once everything is apart it’s very easy to adjust. I ended up with a solid 17.5 degrees on both arms.
It’s harder to get the trailing arms out of the way than anything.
And as a bonus you can check the full travel of your wheel and tire combo to check for rubbing. |
Posted: Sat May 26, 2018 1:46 pm Post subject: Re: Raising My Ghia's Rear Suspension |
I'm not sure how much I want to raise it but I want it raised enough so the back is slightly higher than the from so I'm looking down at my hood and not over my dashboard. I'm 6ft tall so Im not small but I like to feel like Im sitting up in my car not down inside of it. Hope that makes sense. Thanks for all the feedback (and jokes) it's def a help. My dad is the experience car guy so Im running all this past him and he and I will be able to make it work Im sure. |
myghiarocks Samba Member
Joined: June 02, 2009 Posts: 143 Location: DFW area Texas
Posted: Sat May 26, 2018 2:18 pm Post subject: Re: Raising My Ghia's Rear Suspension |
[email protected] wrote: |
Sounds to me that you want the front end lowered and probably not the back.
Post a few picks of your car. You probably need drop spindles and a lowered front beam.
Stock Ghia's sit high in the front and by your description this is probably how the car is set up at the moment. |
Posted: Sat May 26, 2018 2:55 pm Post subject: Re: Raising My Ghia's Rear Suspension |
Here is a Pic of the car. As you can see the front is higher than the rear, I want just the opposite.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat May 26, 2018 4:30 pm Post subject: Re: Raising My Ghia's Rear Suspension |
How much gas is in the tank, and is the jack and the spare tire also in the trunk ? An empty tank will raise the front end. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Sat May 26, 2018 6:38 pm Post subject: Re: Raising My Ghia's Rear Suspension |
The rear ride height looks just about optimal. I would not raise it more than an inch, accomplished by a combination of rotating the torsion bar's inner end as well as repositioning the outer end of the bar where it meets the trailing arm. As for the front, it would probably not need to be lowered more than an inch. This would give either a completely level body, or "slightly" raked to the front. Best way would be an adjustable front axle beam. Lowered spindles go down too far, usually 2.5", and you have to drill them for the disc brake backing plates. Then again, you can test the appearance of a lowered front by placing some weightlifting single-arm weights ("dumbbells") inside the front bumper to get the look you want.
Do you have the front tire pressures set to the factory values, of approx. 18psi? |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Sat May 26, 2018 7:53 pm Post subject: Re: Raising My Ghia's Rear Suspension |
Judging by where your Ghia's rear fender arch sits halfway up the rubber of the rear tyre, I think the rear is good where it is. The front could easily be lowered by means of an adjustable beam, as Rome suggests. (And I agree with him on the dropped spindles issue. Not necessary to achieve a slight rake down towaards the front.)
And you won't have tyre rubbing issues either. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Sun May 27, 2018 5:56 am Post subject: Re: Raising My Ghia's Rear Suspension |
While the rear of the car is slightly lower, probably due to sag in the rear torsion bars, it's not too far off from being level. Most of the perceived height difference is due to the fact the front wheel wells are higher to clear the front wheels when turning left/right, this is common in all automotive design. If you place a straight edge across the image, along the upper chrome side molding, you will see that the line is within 1/2"-1" of being in the same place on the front & rear hubcaps. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
doregan Samba Member
Joined: December 15, 2017 Posts: 30 Location: Wyomissing, Pennsylvania
Posted: Sun May 27, 2018 11:22 pm Post subject: Re: Raising My Ghia's Rear Suspension |
There are a couple of youtube videos on raising/lowering the rear.
I have a 1974 vert and it looks a little lower in the rear like yours. I am not aware that it was purposely lowered. I could simply be age-related sag.
You can always skip the suspension issues and just put slightly larger diameter tires on the rear and slightly smaller diam. on the front. |
Posted: Mon May 28, 2018 3:53 am Post subject: Re: Raising My Ghia's Rear Suspension |
doregan wrote: |
While this will work to level the car, it would aesthetically exaggerate the difference in wheel gap making it look more lopsided. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon May 28, 2018 1:14 pm Post subject: Re: Raising My Ghia's Rear Suspension |
I think if you are judicious in the sizes (diameters) and types of tires you use, you can use a slightly larger diameter tire on the rear and slightly smaller diameter on the front and it will look fine. Problem is that there is not much to choose from if you are trying to maintain the same aspect ratio and still fit on a 4.5j-15 rim.
I have 205/60R15 tires on mine (below) on Pedrini rims. The wide tires makes the steering pretty heavy. I had a '67 Ghia some 40+ years ago and it handled well. I might just get rid of the tires (and possibly the Pedrinis) and go with stock wheels and 165R15 Nexen radials. Maybe slightly oversized in the rear to level the car or get a slight rake.
In the long run, adjusting the rear torsion bars could be your easiest solution. Probably cheaper too.
MontyOnWheels Samba Member
Joined: January 06, 2018 Posts: 2 Location: Middle Georgia
Posted: Tue Jul 10, 2018 7:34 pm Post subject: Re: Raising My Ghia's Rear Suspension |
Does anyone know the stock rear ride height? The measurement from pavement to the top of the wheel house arc?? (obviously stock tire size) |
kurt912 Samba Member
Joined: October 20, 2014 Posts: 158 Location: The Woodlands Tx
Posted: Thu Jul 12, 2018 11:04 am Post subject: Re: Raising My Ghia's Rear Suspension |
With that car inclined on the ramp and the parking brake set it will squat in the rear a little bit. Is there a pic on flat ground? _________________ 1964 MG Midget MK1 Monte Carlo Replica
1969 Karmann Ghia Coupe
1972 Mercedes 250 Coupe |
mnwesty Samba Member
Joined: June 30, 2010 Posts: 66 Location: St. Charles, MN
Posted: Tue May 05, 2020 8:54 pm Post subject: Re: Raising My Ghia's Rear Suspension |
kurt912 wrote: |
With that car inclined on the ramp and the parking brake set it will squat in the rear a little bit. Is there a pic on flat ground? |
I don't know what's been done since the last posting, but this is a side view of our 1971. The rear looks lower than your, but the bottom is dead even with the street.
_________________ Brad Spear
1971 Karmann Ghia
1972 Westfalia
St. Charles, MN |
