rjlatherow Samba Member
Joined: January 12, 2005 Posts: 135 Location: Tarpon Springs
Posted: Fri May 25, 2018 12:25 pm Post subject: Anyone want to interpret compression test result on 24v VR6? |
I have a 02 EV with a bad head gasket (instantly pressurized coolant). Before I take the heads off, I did a compression test for the LOLs.
110
160
30
190
110
145
I had to shake water out of the tester a few times. So aside from confirming my motor is messed up, what have I learned?
-rj _________________ -----------------------------
<---- My sad, sad avatar is my perfect 1970 Squareback on fire - 1/1/05. Magnesium burns really pretty. Use a full trailer. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12103 Location: Port Manteau
Posted: Fri May 25, 2018 1:24 pm Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
A leakdown test would help you pinpoint, but with #s like that, you're gonna get in there and find out anyway. My guess is that you've got a burned valve or a collapsed ring land. How does the oil look? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Fri May 25, 2018 1:45 pm Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
Slightly creamy - like hersheys syrup. Not full on chocolate milk, but there is def some head gasket horror going on. _________________ -----------------------------
Posted: Sat May 26, 2018 4:05 pm Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
May your favorite deity shine goodness and light upon you. I think you're in for a rough patch ahead. _________________ Casey--
y u rune klassik? |
Posted: Tue Jun 19, 2018 7:00 am Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
Head gasket was a mess. Took head to machine shop, head came back okay, had it machined and valves done. Replaced timing chain guides, water pump, and tensioner on principal. Got it back together, and will try and start it for the first time this afternoon when the tensioner gets here. I'll burn some incense and leave out a can of sprite and a bowl of rice for luck.
Posted: Wed Jun 20, 2018 6:54 am Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
Update: She lives! The sprite worked!
The last part finally came in (tensioner, PO stripped the pulley nut.) I turn the key, and nothing.....for about 30 seconds of cranking (5 second intervals with pauses, I'm timid and imaging oil pumps priming and passages filling up). Then, poof, starts and purrs like a kitten. No rumble, quiet, no codes. I'm stunned.
My plan is to run it a few times for 5 minutes or so, then throw in some flush and drain the oil. It was so nasty in there, I just want to make sure it is all cleaned out. I usually don't do the flush, but in this case it sounds like a good idea-
Thank you all for your help! This is officially the most major thing I've ever done to a car, far more so than completely rebuilding the aircooled motors in my old bus.
Oh, and in case anyone wonders, timing the camshaft 180 out is fine . I didn't notice till later that while I was at ADC, my cam was 180 out. My steel plate I used to lock the cams fit inside the head unlike the VW tool, so even though the slots were horizontal they were wrong. Makes sense that it would be fine, I was just nervous.
Posted: Wed Jun 20, 2018 7:21 am Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
Congrats on your accomplishment and the positive outcome. _________________ Casey--
y u rune klassik? |
ELO78 Samba Member
Joined: September 18, 2015 Posts: 167 Location: Oak Park, IL
Posted: Fri Jun 12, 2020 4:10 am Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
What are the compression test specs for the 24V VR6 per VW or the Bently?
I found this on the Web for the 12V:
Quote: |
new: 147-191 psi
wear limit: 110 psi
maximum difference between cylinders: 44 psi |
In another thread I saw the results of a compression test for a 24V reported as 225-230 psi.
EDIT: A thread on VWVortex states that 24V AXK compression test spec as 140-180 psi.
I ask because I'm having a PPI done on a 2001 EV MV with the 24V with almost 195k miles on it. I'm thinking a compression test would be wise. FWIW the timing chains, guides, seals were done at 173k miles.
Any other tests that can be performed to better understand engine health? A test for combustion gases in coolant? I understand a leakdown test could follow the compression test, if necessary.
Thanks! _________________ Eric
1990 Westy Multivan, 2.1 L WBX, 4-speed - SOLD
2003 EuroVan Westy Weekender |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Fri Jun 12, 2020 8:42 am Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
Compression ratio of 10.75 would make nominal cylinder compression 160 psi so that AXK number is on point _________________ .ssS! |
ELO78 Samba Member
Posted: Fri Jun 12, 2020 9:09 am Post subject: Re: Anyone want to interpret compression test result on 24v VR6? |
Thank you, sir! _________________ Eric
