ptspringer Samba Member
Posted: Fri May 25, 2018 1:28 pm Post subject: Swingaxle bearing |
Help please. I need to replace my drivers side rear swingaxle bearing on my 66 bug. The bearing I bought from CIP1 has some sort of retaining ring on it (see photo). Will this interfere with the assembly or oil seal?? I don't recall this ring on the current bearing in my car. Does this look like the right part VWC-311-501-283-GR Ger RR S/AXLE BR T1 46-68
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri May 25, 2018 1:30 pm Post subject: Re: Swingaxle bearing |
take the circlip off. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Fri May 25, 2018 2:13 pm Post subject: Re: Swingaxle bearing |
And put the groove to the inside? |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Fri May 25, 2018 2:44 pm Post subject: Re: Swingaxle bearing |
The circlip is included with the bearing because that bearing can have other applications needing it. (Not just VW) _________________ '63 Ragtop |
Posted: Fri May 25, 2018 6:44 pm Post subject: Re: Swingaxle bearing |
That makes sense, and thank you. When I remove the circ clip I want to be sure the resulting groove does not interfere with the o-ring or oil seal. Hopefully if I put the groove on the inside it will be covered by the bearing recess in the axle. |
