gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1468 Location: San Carlos, CA
Posted: Thu Aug 02, 2018 8:21 pm Post subject: Re: 1958 Outlaw Beetle Build |
Joe-
Regarding the Solex's, I found this quote on the 356 Carburetor Rescue site:
If you are considering switching from a Zenith to a Solex
carburetor, remember the choice of carburetor is dependent
on the Cam in your engine, not the installation of a "big bore
kit'. Lower reving engines (4500 / 5500 rpm) - stock 1500 and
1600 engines as used by the A, B, and C cars - need to use
Zeniths with their smaller 32mm bore. SC's and later cars,
comfortably running to 6,000 rpm, can accomodate the 40mm
bore of the Solex carburetors. Without the right cam,
switching carburetors will not gain you any advantage.
Would you agree with this statement?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
sled Samba Member
Posted: Fri Aug 03, 2018 6:08 am Post subject: Re: 1958 Outlaw Beetle Build |
SO many people over-carburate their engines because it looks cool, not considering what the actual optimum carburetor would be.
NDIX's are a much better match for this small engine. _________________ drive your split. |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Fri Aug 03, 2018 10:38 am Post subject: Re: 1958 Outlaw Beetle Build |
Hi Paul,
Since i've never driven a car with dual Zeniths, I couldn't give you a personal/honest answer about 40mm vs. 32mm carb bores. What I do know is when i'm on the freeway going about 70mph+ and "give it some juice", the car responds sooo gooood and always runs cool. Maybe because I have a Pro Street transmission with a 412 R/P? I'm always going past the RED on my tach. but the engine doesn't seem to mind? The Ghia just wants to run all day long. I'm running a Pre-A SUPER camshaft that I had Web-Cam "rework" and seems to work fine with these carbs. I'm going to put together a Denzel 1500cc with 40X35 heads running Weber DCM carbs. and pull this engine out to see what kinda HP I can get out of it.
gimmesomeshelter wrote: |
Joe-
Cheers,
Paul |
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Big_E_Deluxe Samba Member
Joined: September 23, 2013 Posts: 261 Location: Charlotte, NC
Posted: Fri Aug 03, 2018 10:53 am Post subject: Re: 1958 Outlaw Beetle Build |
Paul,
356 Carburetor Rescue (Jim) in AZ rebuilt my 40 P-II's specifically for my stroked engine. I guess you never know for sure unless you try. We're going to give it a shot and see how it goes. If it doesn't work, then we'll put the current setup back on. I can always build another larger engine and put the 40 P-II's on that.
_________________ Erik
1958 VW Beetle - "Max": https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
1959 VW Bus - "Hans" - Double Door Panel (sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=746927
2014 Porsche 991.1 Carrera S |
Danwvw Samba Member
Posted: Fri Aug 03, 2018 12:56 pm Post subject: Re: 1958 Outlaw Beetle Build |
Been following these vintage 36 horse threads lately. Very impressive. Got to love the look of those huge old Porsche Solex's on them. It's amazing you can actually do it. The 26mm Venturi sounds right to me.
I have driven the 356's with both the little Solex PBIC-32's and the Zenith NDIX 32's. The little Solex were well behaved and really a pretty nice match for the (74mm Stroke)X(82.5's) Porsche 356A engine. But the Zenith NDIX-32's were more fun as well as more cantankerous.
I installed Dual Porsche Zenith NDIX-32-25's on my 1679cc VW Type 1 dp engine and feel they are the best match for it over the Dual Dellorto 36-28's.
Can't wait to see your vintage 36 horse with the Big Solex 40 P-II's.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Aug 03, 2018 12:59 pm Post subject: Re: 1958 Outlaw Beetle Build |
While my heart argured "Go with the Solex carbs. They are soooo cool!", I listen to my head, and had Jim rebuild a set of Zenith's off of a '62 356 Super. They're smaller, less expensive to rebuild, and jets are plentiful (in Europe). Here's a crappy picture.
Good luck with the Solex carbs. I can't wait to hear those bad boys scream.
Cheers,
Richard Feynman |
Posted: Mon Aug 20, 2018 10:18 am Post subject: Re: 1958 Outlaw Beetle Build |
Did Tarbari provide new shafts, or did you provide your own?
Cheers,
Richard Feynman |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3987 Location: Antioch, California, a block from the hood
speedy57tub Samba Member
Joined: August 22, 2002 Posts: 4 Location: Sin City Las Vegas, Nevada
Posted: Mon Oct 22, 2018 12:17 pm Post subject: Re: 1958 Outlaw Beetle Build |
Very nice build, I am really enjoying your post. Where the wheel bearings different on the fronts due to differences between the 356 B and VW spindles shafts? Looking at my parts, it appears that the outer bearings have different inner diameters.
Tony _________________ Meanwhile, back at the farm....... |
Posted: Mon Oct 22, 2018 12:37 pm Post subject: Re: 1958 Outlaw Beetle Build |
speedy57tub: We used beetle bearings upfront. The outer diameter of the bearings will fit the Porsche drums. Sorry but I don't know the part number for this. Make sure you get the correct castle nut in the rear as well to clear the exposed axle splines. You don't want your castle nut bottoming out on them. You need an early Porsche castle nut. Looks like photos below, large bevel on the back side to clear splines. Some people have used washers and the stock VW castle nut to clear, but this is not a good condition.
The Porsche backing plates will bolt onto the stock spindles and rear axles. If you are using dropped spindles you will need to modify the Porsche front backing plates to clear the relocated spindle. I think I have a picture in the thread somewhere showing the small half round cut we made to clear dropped CB spindles. The brakes are excellent and worth the effort. But it's hard and expensive to find all the correct bolts and inner parts. Some parts you have to find used.
Good luck and thanks for the compliments! _________________ Erik
Texbug Samba Member
Joined: August 06, 2005 Posts: 82 Location: Ft. Worth
Posted: Mon Oct 22, 2018 5:18 pm Post subject: Re: 1958 Outlaw Beetle Build |
Hi Erik,
Where did you find these castle nuts? I’ve been looking for some like you have pictured but haven’t been able to find. Thanks in advance for your reply.
Mike |
Posted: Tue Oct 23, 2018 8:09 am Post subject: Re: 1958 Outlaw Beetle Build |
Texbug wrote: |
Hi Erik,
Mike |
I've had luck finding them on eBay as well as AASE. AASE sells nice used & new 356 parts, you just need to check it from time to time. I have another set, but they're not for sale. I'm slowly assembling another complete set of B brakes.
Link: www.aasesales.com
Good luck! _________________ Erik
Posted: Tue Nov 06, 2018 9:50 am Post subject: Re: 1958 Outlaw Beetle Build |
An update on Max.....
Engine: 1500 miles on it and it's running better then ever! Found that the points needed a slight adjustment. After the adjustment, the engine has come alive. Very impressed by it every time I take it out. Again, it's not going to break any records, but just to think it was once a 36hp, just makes me smile. Thanks Joe! Side note: We decided not to install the ratio rockers. We had some rubbing associated with the push rods and tubes. Maybe at some later date we will revisit. Back burner....Solex 40's. It's running so good, want to enjoy it.
Interior: Replaced existing door panels with a set of Lenny Copp red/brown & grey panels. These new panels match the current seat covers/colors correctly.
Suspension: We are still running 185's front & rear. This alone improved cornering, lots of grip. We were able to raise the front about 1/2" to resolve tire rub on front fender lip. Solution was to remove the smaller half size torsion leaves and replace with the larger bar. We removed 4 of the small bars (2 from top tube & 2 front bottom tube) and still have 4 small bars in the total mix. This reduced suspension pre-load slightly, gaining 1/2" in height. We were not sure if it would work but it did. Cornering improved dramatically with stiffer setup & reduced body roll up front. In the rear we replaced stock 60 year old torsion bars with 24mm Sway a Way bars. This stiffened up the rear squat but not too much. All of these chances together made corner a lot more fun. Stance is now level at the running boards. I think it looks great and it's very practical to drive around town, love it!
After the suspension tweaks I attended 2 shows in one weekend covering 400 total miles in Max. Crusing the highway at 70mph at 3k rpm. Only issue was on last day the points needed to be adjusted, had a hard time starting. Other then that it was a fun weekend and drive. Along with that we received some recognition for our hard work. 1st Place win in VW Class at Euro Fest 2018 along with a special recognition award from show sponsors. 2nd day we received a 1st Place win in "Modified Pre-'58 Class at Fast Times at Farmington. Pretty cool for not trying to build a show car.
No big plans on the boards right now for Max, just enjoy the cooler temps and drive as much as possible. I'm hoping that we will get some snow in Charlotte this year.... Yes, I will be taking it out for a "spin"!
Last edited by Big_E_Deluxe on Mon Nov 12, 2018 6:21 am; edited 4 times in total |
JWDII Samba Member
Posted: Wed Nov 07, 2018 11:43 am Post subject: Re: 1958 Outlaw Beetle Build |
Erik,
Congrats on all the recognition of your efforts at the two shows! It is well deserved. You beetle is stunning in person! Thank you for taking the time to chat with me at the Farm. It was a pleasure meeting you.
John _________________ this space for rent. |
Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Posted: Wed Nov 07, 2018 1:59 pm Post subject: Re: 1958 Outlaw Beetle Build |
Simply awesome. What a cool car!!
That's my goal on my '54 oval. Now I installed an adjustable beam with stock spindles, caster shimsand a sway bar, and raised the car a bit (before it has dropped spindles, too much drop). Set the koni shocks at the softest setting, installed the 165's again (before 145's because it has rubbing problems).
Now the car handles!! Next step is install 58-64 drums (thicker brake pads) and maybe some 356 style wheels, like yours.
Next will be a vintage speed inspired 1835cc, 4,12 trans, black mamba shifter and a power brake system.
Again, I love your car, is an inspiration for my build!! |
Posted: Mon Nov 12, 2018 6:29 am Post subject: Re: 1958 Outlaw Beetle Build |
JWDII wrote: |
Erik,
John |
Hey John...it was a pleasure talking to you as well. Hope to see you again soon, E _________________ Erik
Posted: Mon Nov 12, 2018 6:32 am Post subject: Re: 1958 Outlaw Beetle Build |
Albertoprop17 wrote: |
Sounds cool. Post up a picture, would love to see it. I messed with the Koni's a bit and also found that the softest setting felt the best. Good to see that you felt the same way. Good luck on your future upgrades, keep us posted. BTW, I saw your post on the control arms, very interesting. I've never seen those before. E _________________ Erik
