jkolak Samba Member
Joined: July 01, 2004 Posts: 72 Location: Independence, MO
Posted: Fri May 25, 2018 10:03 pm Post subject: 1978 Passat B1 Horn Wiring |
Hi,
I have a 1974 dealer service manual (Bentley), and the dealer faithfully installed the updates through 1976, but my 1978 is different.
If anyone has a 1978 wiring diagram, that would be great. Otherwise, if I could just find out what pin numbers on the relay block are for the horn, that would be sufficient.
I have the right hand drive Passat. A German source told me that that means I have the 1977 dashboard instead of the newer 1978 style that the Dashers in the US got. I'm not sure what that means for my relay box and wiring, but the 1976 wiring diagram is definitely wrong for my car.
Thanks.
sgnimj96 Samba Member
Joined: May 14, 2015 Posts: 48 Location: Melbourne, FL
Posted: Sun May 27, 2018 6:20 am Post subject: Re: 1978 Passat B1 Horn Wiring |
on my mk1 sciroco the horn ground is the the steering wheel, the the horn has 12v all the time. The steering wheel button is usually the problem.
All that old vw wiring is pretty similar. I have a clymer manual (rabbit 75-81) that has good wiring diagrams included and most the wirings are the same except for california emissions.
Nevertheless, you have a 40 year old car so rewiring stuff and relaying high-amp stuff like headlights is a good idea. It's as simple as car wiring probably gets.
Also, those year manuals are floating around for cheap - lucky you
https://www.ebay.com/itm/Volkswagen-Dasher-Service...SwKOJa-bXw
https://www.ebay.com/itm/1974-1975-1976-1977-Volks...0005.m1851
Amazon has em' too. |
jkolak Samba Member
Posted: Mon May 28, 2018 7:49 am Post subject: Re: 1978 Passat B1 Horn Wiring |
Oh! I have that Clymer! I don't know why I didn't think of it, but it matches my 78 Passat!
It's amazing that the 75 Rabbit diagram is right for my 78 Passat, but the 76 Dasher diagram is wrong. I guess it took them a while to bring the Passat up to date with the new standard. In my 76 Dasher wiring diagram, the horn power goes from:
D19 to horn button to E11 to A7 to horn to ground.
In the 78 Passat and 75 Rabbit, it goes from:
A11 to horn to A7 to E11 to horn button to ground
So both diagrams share A7 and E11 in common, but the old style grounds after the horn and the new style grounds after the button.
I was going crazy with nothing at D19 in my plug. Thanks for your help! |
