Frodge Samba Member
Posted: Sat May 26, 2018 3:26 pm Post subject: Rear window seal |
Who still has original rear window seals in their bugs? J |
ricaroo Samba Member
Posted: Sat May 26, 2018 4:13 pm Post subject: Re: Rear window seal |
How would you know?
Rick _________________ 1971 Standard Beetle 2 dr Sedan 1600dp |
gt1953 Samba Member
Posted: Sat May 26, 2018 4:39 pm Post subject: Re: Rear window seal |
I have reason to believe that most of mine are original. Its a 68, they are really dry out and a lil brittle. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Frodge Samba Member
Posted: Sat May 26, 2018 4:45 pm Post subject: Re: Rear window seal |
Mine looks pretty good. I have some 303 aerospace protectant which really works wonders in keeping convertible tops supple. Is this good to use on the gaskets? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Sat May 26, 2018 5:17 pm Post subject: Re: Rear window seal |
Frodge wrote: |
Who still has original rear window seals in their bugs? |
ricaroo wrote: |
How would you know? |
Well, one knows if one has had the VW since it was 2 years old, like the case with me and my 1970. Well, my 1970 still had the original rear rubber seal until 1.5 years ago, when I replaced it due to leakage. Its windshield seal is original, the windshield was replaced in the 1970s. Its quarter window seals are original too. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Frodge Samba Member
Posted: Sat May 26, 2018 5:22 pm Post subject: Re: Rear window seal |
Do you think the leakage is from dry rot from the Arizona sun? 🤡 |
Cusser Samba Member
Posted: Sat May 26, 2018 5:31 pm Post subject: Re: Rear window seal |
Frodge wrote: |
Absolutely. I built a 28.5 foot long carport on the side of the house back in 1995, would've been significantly more difficult to go longer than that because the block fireplace jutted out at the end. We parked a 1988 Suburban under that, and not enough room to cover the entire 1970 VW, which sat there with its hind end facing the Arizona mid-day sun from 1995 until I started resurrecting the VW in late 2016.
My daughter and I replaced the rear seal, and it was much easier than when we did the rear seal in my 1971 convertible a few years before, because of the "give" in the soft top. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat May 26, 2018 7:57 pm Post subject: Re: Rear window seal |
my rear window seal is original and no leaks _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Cusser Samba Member
Posted: Sat May 26, 2018 8:23 pm Post subject: Re: Rear window seal |
Cusser wrote: |
Frodge wrote: |
ricaroo wrote: |
Well, one knows if one has had the VW since it was 2 years old, like the case with me and my 1970. Well, my 1970 still had the original rear rubber seal until 1.5 years ago, when I replaced it due to leakage. Its windshield seal is original, the windshield was replaced in the 1970s. Its quarter window seals are original too. |
My '71 convertible has its original front windshield rubber and original windshield glass. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Sat May 26, 2018 8:38 pm Post subject: Re: Rear window seal |
All my seals and glass, save the windshield, which I replaced, are original. The seals are also all cracked, and brittle. The don't leak though. I coated them with some sealant about 7 months ago. _________________ Daily driven....Slowly. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
OldSchoolVW's Samba Member
Posted: Thu Jun 30, 2022 2:43 pm Post subject: Re: Rear window seal |
Unless the supplier says they are the manufacturer, it's possible, even likely, that the suppliers are getting the seal from the same source. West Coast Metric says there's is made in USA for WCM:
https://www.westcoastmetric.com/i-22964825-113-521j.html _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Johnny Martin Samba Member
Joined: August 31, 2010 Posts: 454 Location: Buffalo, NY
Posted: Thu Jun 30, 2022 3:53 pm Post subject: Re: Rear window seal |
I just did my seals on the whole car, I used west coast metric. They went in very nice. Not one complaint _________________ 1971 SUPER BEETLE
AE489501 carb Solex 30 pict-2 with dist 0 231 137 021
113 905 205 M |
Posted: Thu Jun 30, 2022 8:00 pm Post subject: Re: Rear window seal |
Thanks yall _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
