richierich Samba Member
Posted: Tue May 29, 2018 3:53 pm Post subject: Can't get oil pressure light on dash |
I have put my oil pressure switch in the AN fitting coming out of the filter housing into the case (braided hose). Switch is hooked up and I have run an earth from the filter housing (cleaned up the mount for the filter mount to bare metal) to the same earth point on the body where the battery is earthed. Oil pressure light does not come on at all. Any ideas?? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue May 29, 2018 4:01 pm Post subject: Re: Can't get oil pressure light on dash |
Check to see you get voltage to the sender when key is on. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Tue May 29, 2018 4:02 pm Post subject: Re: Can't get oil pressure light on dash |
Verify at the bulb holder that you do have ground when the engine is no running and positive when the ignition is turned on, if you have both of those then the bulb is no good. |
Dale M. Samba Member
Posted: Tue May 29, 2018 8:02 pm Post subject: Re: Can't get oil pressure light on dash |
Ground wire to lamp at pressure switch, turn key on does lamp come on?
No light, check bulb (bulb socket) or wiring.
Yes light, pressure switch bad of no ground on switch.
Posted: Wed May 30, 2018 9:25 am Post subject: Re: Can't get oil pressure light on dash |
Ok - I'll chase it down. It's odd as the light worked fine before I shifted the switch to its current position |
Zed999 Samba Member
Posted: Wed May 30, 2018 10:08 am Post subject: Re: Can't get oil pressure light on dash |
Check continuity between connection on switch and body/engine. If none either switch is duff or your earth connection. To check switch check continuity between switch connector and body. |
