67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Tue May 29, 2018 8:10 pm Post subject: The coolest accessories you’ve purchased for your bug??? |
Let me hear about them!
Things that have made your bug more driveable or more fun to drive or have solved some of the bug’s known “issues”
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed May 30, 2018 7:19 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
... am not a fan of extras on my VWs..,. the simpler, the better. The first VW, I had was a 1965 bug, purchased new in1966.. it had zero accessories and even a radio delete... really liked the ones from, up to 1961 with no gas gauge, just a speedo...
All my VWs today, sport a radio-delete and no antenna. Although, one of my '55s (has, not by choice) an extra (amp) gauge, a windshield washer pump (which I removed), an auxiliary gas heater (which I never use or even tried to see if it functions) and rear pop-out windows (which, I must say - I love)
The only accessory, all my type one cars have is a carry-over design from the pre 10/1952 era - a removable access panel behind the rear seat... originally used to access the trans filler plug.
Since, I have been spoiled, owning at least 5 early, very basic split bugs with this access panel - to easily reach the 2 upper engine bolts, fuel filter, starter and connections, easier trans filler access and easier clutch adjusting access... I consider this the accessory VW abandoned for the do-it-yourselfer or senior citizen who has a tough time reaching all this from the bottom - underneath.
This is the number one accessory, I construct in all my type one vehicles, including Karman Ghia and the first thing I did on my relatively-expensive five-figure '55 bug.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Wed May 30, 2018 7:45 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
This doesn't look very attractive in this instance, what does it look like on the splitties? I have an oval that someone hacked an access hatch with appears to have been a hammer, chisel, & can opener, this would be a great way to patch this damage without having to replace the whole firewall.
Eh, mine is a lot worse than I remembered.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed May 30, 2018 8:15 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
TDCTDI wrote: |
... oh sorry, you don't approve or like the look... I just do the best I can... never think about attractive... think more of function AND besides, once the cover is secure and the German square weave is rolled over it to cover my work, no one would be the wiser of this GREAT accessory and my unsightly (to some) handiwork.
I have learned, in my 70 years to do what works for me and not be too concerned what others think. I am used to other points of view that differ. We all can't agree on everything as there are many ways to view everything...
Yeah, looks like your access might need a little tidying up.. the PO had a great idea, just cut it differently than the way I did... I trust you'll take care of it nicely... what a great accessory, for the future... cover it and keep it to yourself and no one will be the wiser, LOL unless you're like me and want to boast 'bout a great idea... cheers! _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Wed May 30, 2018 8:25 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Sorry. WHAT A GREAT IDEA!!! Would you happen to have pictures of the factory access hatch that you could share with us? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed May 30, 2018 8:39 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
TDCTDI wrote: |
Sorry. WHAT A GREAT IDEA!!! Would you happen to have pictures of the factory access hatch that you could share with us? |
... initially, to gain access to the trans fluid filler... but there's so much more under there...
pop out windows are the best accessory, _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Wed May 30, 2018 8:52 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Thank you sir. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Wed May 30, 2018 8:58 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Quarter pop-outs, sliding Sunroof, and the vent wing windows. Moves a ton of air. More options than accessories though.
My favorite accessory is my bamboo parcel tray. Super handy and vintage look. I like my roof racks too. Easy to put on and off depending on look or need. Clear tubing and felt pads and no paint issues. |
Posted: Wed May 30, 2018 12:25 pm Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Thanks for the replies guys. That hatch is awesome. I should consider it myself. I went with pop outs also. I guess there is better wind movement with them. I had one piece windows on my first bug and people have told me to steer clear of them-lots of problems-so I kept my vents on this bug.
Is a battery cutoff switch necessary?
What about the oil temp thing that attaches to your dipstick?
Or an alternator instead of a generator?
And I’m doing the headliner soon-what type of material for the roof? Jute? Quick roof? I don’t want it to fall off when it’s hot out. |
Posted: Wed May 30, 2018 1:46 pm Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
I've never done the cutoff switch or oil pressure dipstick thing. I've had great success with the perforated vinyl headliners. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed May 30, 2018 1:56 pm Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
A "for sale" sign. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Wed May 30, 2018 1:58 pm Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Berg 5 with a ZF LSD
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu May 31, 2018 4:42 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Damn...
Mid Engine Bug Samba Member
Posted: Thu May 31, 2018 10:34 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
To make mine more fun/reliable to drive, I converted over to fuel injection....
_________________ 1970 Bug Shell - the rest of it, well see for yourself...
https://www.thesamba.com/vw/forum/viewtopic.php?t=679467 |
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
Posted: Thu May 31, 2018 11:07 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
I think I've used this accessory more than any other
_________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu May 31, 2018 11:24 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
I put little changes in my old Bugs (and my current Fastback) using VW parts from later/earlier/other models. Kept the Wolfsburg blood intact, and made it easy to find parts should something go wrong (back when there were VW parts stores and dealers everywhere).
This included little bits like pop-outs, foglamps, amber turn lenses, a highback driver seat in my '67 for safety, added fusebox (original located on the passenger side where there was a pressing for a stock fusebox for RHD cars), backup lamps on my '65; for the Type 3, side parking lights, pop-outs and a factory sunroof on my fastback, 3-point inertial belts... H4 halogen headlamps and headlamp flasher (passing) relay for both...
I felt these were changes VW would (or did) do to improve things, but not to just keep up new appearances, just make it more practical, comfortable, reliable, etc. Nothing dramatic. |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Thu May 31, 2018 11:45 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
The coolest thing I've put on my bug are some of Randee's extended pop out latches on my oval rag ( Thanks RareAir) and a Dehne Fuel gauge i'm currently restoring for my Vert. On my list is a Perohaus clock. _________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
Posted: Thu May 31, 2018 12:13 pm Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
slave1pilot wrote: |
Amen to that!!! |
Posted: Fri Jun 01, 2018 4:49 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
Yes the tow bar is awesome. Got one!
Holy crap! Mid engine, fuel injected, supercharged bug?!!!
Hahahaha! WOW.
What size supercharger? Eaton M45? |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 700 Location: long Island new york
Posted: Fri Jun 01, 2018 5:38 am Post subject: Re: The coolest accessories you’ve purchased for your bug??? |
how did we get so negative!
_________________ Enjoy the ride....
72 bug
80 westfalia |
