spectre1995 Samba Member
Joined: May 06, 2018 Posts: 57 Location: El Segundo, CA
Posted: Tue May 29, 2018 10:23 pm Post subject: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
My local VW store has a front disc brake conversion special going on. I'm thinking of picking up the "Econo Quality" set for my 73 Super which I've been told is an EMPI product, made mostly in China. The "Good" quality set for $100 more is still mostly made in China, but has some components made in Brazil.
Has anyone ever used these particular disc brake conversion sets before? I'm not looking for anything fancy (particularly not looking for anything that will break the bank) so that's why I'm deciding to go with one of these budget sets.
https://imgur.com/a/Te7znRx |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Tue May 29, 2018 10:30 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
I have purchased and installed front disc brakes from Empi for years. I figure if something goes wrong with the brakes and The outcome is less than favorable, my family has a deep pocket to go after!
I hate saying this, but I have not had any issues, knock on wood, yet. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
bobinphx Samba Member
Posted: Tue May 29, 2018 10:44 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
When I got my 69 standard, it disks on it. They were partially frozen. I replace them with empi and they work very well. Note that I did have really bad squealing with the supplied disk brake pads. I swapped them out for a pair from autozone and have had no issues since. I have also been watching wear patterns and have found no issues.
so, although its not a super, I have had no issues. |
Posted: Tue May 29, 2018 10:52 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
If you guys don't mind me asking, what did you all pay for your EMPI kits? |
Chris333 Samba Member
Posted: Tue May 29, 2018 11:14 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
Pretty much looks like it. The one from the local VW place is $215 and looks like it includes quite a bit more hardware as well |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue May 29, 2018 11:28 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
I received my Empi front disc conversion as a birthday present, five or six years ago. My wife paid $229 for the Super Beetle kit. I’ve had no issues with the conversion, except for initial squealing, due to the supplied pads which were apparently too soft. I had planned to replace them but they haven’t worn much, and the squealing stopped after awhile.
This kit contained well-made rotors, pads, calipers, metal brake lines that required bending, and all the hardware—including spacers for centering the caliper. No new bearings, races, or inner seal, however.
Since five years have passed, i would have expected the price to go up; but the Econo set you’re looking at is somehow even cheaper—and it seems it contains new bearings, on top of what I got. I would be leery of that one. Chinese bearings are not the best, from all I’ve heard. And even without the bearings, your kit is still cheaper? This kit may not be the same Empi setup I got.
I’d ask the vendor why the “Good” kit is $100 more. For all you know, the Econo setup may not even be Empi.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Wed May 30, 2018 7:36 am Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
I have the Empi front disc conversion on my 68 Sedan. Fitment and function are good. With the exception of the drop spindles, all parts are replacements OEM disc brake components for the later Karmann Ghia and Type 3 (correct me if wrong). I haven't put alot of miles on my Bug, but what I have driven this brake setup works good enough for me.
-Nick- _________________ -Why buy it when you can BUILD it?- |
rjplumer Samba Member
Joined: March 16, 2010 Posts: 58 Location: Foxboro,Ma
Posted: Wed May 30, 2018 4:42 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
Recently installed the EMPI disc brake conversion kit on my 74 Standard Bug and I think it works great. I just had to make sure they were bled properly but afterwards they worked great. So far they work great although I haven't put a lot of miles on it yet. It's a fairly simple swap although. You'll need to replace wheel bearings too. _________________ Current VW: 1974 VW Bug(Standard) https://www.thesamba.com/vw/forum/viewtopic.php?p=8505350#8505350
Previous VW: 1971 VW Super Beetle |
Posted: Wed May 30, 2018 5:31 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
I bought mine off Amazon for $377.00 with the dropped spindles included. _________________ Jimbo
TDCTDI wrote: |
Uberchin Samba Member
Joined: April 07, 2018 Posts: 26 Location: San Antonio, Florida
Posted: Wed May 30, 2018 6:05 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
In my opinion, a 'good disc brake kit that was made for the vehicle is almost always better than the drum brakes they replace. This implies that they are properly installed, bled,and the rest of the brake system is in good operating condition. |
Posted: Thu May 31, 2018 3:26 pm Post subject: Re: EMPI Front Disc Brake Conversion - 1973 Super Beetle |
So I ended up getting the "economy" kit, but paid a bit extra for better bearings. Everything went smoothly on one side, but unfortunately one of the rotors is out of tolerance, as one of the races for the bearings is turning inside its passage in the rotor. I see why these were the cheap ones, but at least they're fully warrantied.
So now the poor Beetle has to sit on jackstands for a day until I can get the replacement rotor when it comes in tomorrow. |
