62kellison Samba Member
Posted: Thu May 31, 2018 1:23 pm Post subject: 6 or 12 volt switches in my buggy? |
guys a have a 62 frame it was a 6 volt system.nothing was hooked up completely,don't know if dune buggy ever ran.i put a 12 volt motor/ system/Empi harness in.question is, can I use the headlight/parking light pull out switch that was in the buggy already on my 12 volt system?.it has a white knob,it has prongs on the back labeled with 57,58,30,56,58.I believe its a like 1958 to maybe 1967? switch.can I use this with my 12 volt harness?.and there is a 3 prong dimmer/highbeam switch on the floor.can that also be used with 12 volts?.thanks. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Thu May 31, 2018 2:16 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
@62kellison - Your 6 volt headlight switch and dimmer switch will work just fine with your 12 volt system. What matters most is current, i.e. amperage. A 12 volt headlight will draw half the amps that a 6 volt headlight of the same wattage. My buggy has 1986 Honda CRX headlights with halogen bulbs, and they draw a bit more current than the old seal'd beam type. But on high beam, they draw quite a bit more, being 65 watts vs low beam at 35 watts, resulting in my headlight switch (from 12v stock bug) getting kinda warm when driving for hours at night with brights. |
Posted: Thu May 31, 2018 2:25 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
thanks for the info... |
dustymojave Samba Member
Posted: Sat Jun 02, 2018 4:41 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
What truly matters in whether the switch can handle the load is not Amps, but WATTS. Amps x Volts = Watts. That is the true measure of current flow. _________________ Richard
SoCalBajas Member
Posted: Sat Jun 02, 2018 6:15 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
dustymojave wrote: |
... Amps x Volts = Watts ... |
Very correct.
... Watts. That is the true measure of current flow. |
Actually, Watts measure POWER; Amps measure current flow.
When a switch is ON, there's theoretically no voltage drop across its terminals (meaning no power dissipated). However, in reality there's always a little resistance; hence a tiny voltage drop (meaning some power dissipated, as heat).
From Wikipedia: Ohm's law states that the current through a conductor between two points is directly proportional to the voltage across the two points.
So, amps thru our headlight switch is directly proportional to the tiny voltage drop across the switch's terminals. We can now write that Amperage 'is proportional to' Voltage as:
A ~ V
To make the proportion into an equation, we need a so-called 'constant of proportionality' i.e.:
A = cV
Solving this for V:
V = A / c
And substituting this into the power equation:
P = V*A
gives:
P = (A/c)*A = A^2 / c
So, power is Amperage SQUARED divided by a constant.
Bottom line...
You (dustymojave) and I are both right. Power IS what matters; and, it is directly proportional to the square of Amperage. |
Posted: Sat Jun 02, 2018 7:47 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
Just to clarify that we ARE saying the same thing (but I was trying to keep it simple).
What truly matters in whether the switch can handle the load is not Amps, but WATTS. Amps x Volts = Watts. That is the true measure of current flow. |
MrGoodtunes wrote: |
P = V*A |
In MrGoodtunes post, he was leaving out the simple statement that in his equation and mine:
P (for "Power") is commonly expressed as "Watts".
So...Yep. We're saying the same thing. The switch doesn't much care if the W is high Volts X Low Amps, or if it's low Volts X High Amps. As long as the total watts is within the capacity of the switch.
For instance, the toggle switches that have been in the dash of my 1958 Baja Bug for about 450,000 miles and 45 years are rated at 10A/250V. That works out to 2,500 Watts. So at 12V (or more accurately about 14V as a max voltage for my 12Volt system):
2500W/14V = 178.6Amps
So my switches are rated to handle over 175 Amps in my 12 Volt system. The same switch in a 6V system would take
2500W/7V = 357.1Amps
Both my headlights together on high beam draw less than 6 amps at 12V. That switch is VERY capable of handling that flow.
The stock VW/Bosch headlight switches are rated similar to those toggle switches. Bosch doesn't specify the rating on the housing as is done on my multi-purpose industrial/aircraft toggle switches. That's only because they're for a specific application, not for general purpose. Not only can you use 6V switches in a 12V system, or vice-versa, you also don't need any silly relays that would just over-complicate things and multiply cost. _________________ Richard
SoCalBajas Member
Posted: Mon Jun 04, 2018 3:10 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
got it.thanks guys!! |
EVfun Samba Member
Posted: Mon Jun 04, 2018 4:31 pm Post subject: Re: 6 or 12 volt switches in my buggy? |
2500W/7V = 357.1Amps |
That is so wrong I don't know if I should laugh or cry. Switches don't care about watts of load, only the amps the contacts will carry and the voltage they will be asked to stop when turned off. Both are important for different reasons.
The voltage rating of a switch is how much voltage it can safely shut off without a risk it arcs over and continues to allow current to flow. You cannot use an AC awitch rating to determine the DC voltage it can handle (though as an estimate the DC rating will be about 20% of the AC voltage rating.) You can freely use a switch under its voltage rating, but not over it.
The current rating is all about the heating and failure of the contacts sooner than designed for. If you have a very sensitive ohm meter (not your average digital multimeter) you can measure switch contact resistance. Amps squared times resistance equals watts of heat being created in the switch while carrying that current. Because amps is squared in this equation yoy can see that if the switch carries half the amps it is rated for it will only make a quarter of the heat, and that system voltage is not a part of the equation. It is safe to use a switch for less than the rated amps, but not more.
12 volt auto systems almost always use less current because power is measured in watts (volts times amps equals watts.) A single 35 watt 6 volt headlight draws about 5 amps (car bulbs are designed for charging voltage, about 7 for a 6 volt car and 14 for a 12 volt car.) A single 55 watt 12 volt headlight draws about 4 amps.
**Edited the last word of my post. Thank you to the user who PMed me and pointed out my error! _________________
Wildthings wrote: |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jun 08, 2018 8:16 am Post subject: Re: 6 or 12 volt switches in my buggy? |
The irony of all this discussion (car related) ... Switches, fuses, relays, alternators, generators and wire are all referenced to as AMPS ratings.... About only thing mentioned in WATTS is light bulbs and power required for radio (not specifically power output)...
