skelly Samba Member
Joined: May 13, 2018 Posts: 45 Location: Upper peninsula, MI
Posted: Wed Oct 17, 2018 4:11 pm Post subject: Re: Panel, panel, who's got the body panel? |
Very helpful... thanks Grant! |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Wed Oct 17, 2018 1:44 pm Post subject: Re: Panel, panel, who's got the body panel? |
skelly wrote: |
thanks for all the info in this thread! I've been wondering the same questions. Can anyone tell me what the difference is between a panel and a "skin", if there's any difference at all? |
Basically same thing, "skin" is a term used to describe the metal that is non-structural, covers the structural stuff on the body, and gets most of the paint. Common use of that would be a door "skin" to describe the part of the door that everyone sees from the outside. For older cars it is not uncommon to see someone selling a NOS door skin to replace your rusty or otherwise damaged one.
There are a lot of (largely meaningless) nuances to describing body parts this way e.g. a fender from an old bug would be called "fender" straight off the stamping machine, would not be called a skin or a panel. But the equivalent parts of a Vanagon I would call the "arch" (the curved piece which forms the opening where to the tire well) and around it a body panel. You can also get a single replacement that has both the arch and the rest of the panel, I would just call that a panel. If you called it a skin I would know what you are talking about and wouldn't correct you but it's probably not the most common term in use. _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
skelly Samba Member
Posted: Wed Oct 17, 2018 3:46 am Post subject: Re: Panel, panel, who's got the body panel? |
Spey Caster Samba Member
Joined: October 27, 2017 Posts: 36 Location: Vancouver
Posted: Mon Jun 11, 2018 10:58 am Post subject: Re: Panel, panel, who's got the body panel? |
Thanks Bulli Klinik.
This gives me a great deal of hope. Well done.
Bman is right on the gauge. Needed that. |
Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Wed Jun 06, 2018 8:26 am Post subject: Re: Panel, panel, who's got the body panel? |
The Klokkerdoodle rear fenders are one of the few pieces they make that fits like a factory part. It is a little bit on the thin side at 20G. Factory outer panels for Vanagons tend to be in the 18G realm or close to 1mm.
Their section which goes just aft of the rear fenders is a pretty decent pressing as well.
I don't care for their long-side rockers due to the fact that it eliminates the seam. I prefer my panels to fit like the factory intended. Another downside is that you won't be able to metal finish the upper weld because the lower rocker is attached and it doesn't leave any space to put a dolly behind the panel. I prefer making the upper on the long-side for these reasons, plus it's 18G:
I'm not sure if there is a decent pressing of the lower rocker. In the pic above I replaced the upper half of the lower rocker.
Seam rusted areas which don't require an entire panel get repaired with 18G: _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Tue Jun 05, 2018 9:29 pm Post subject: Re: Panel, panel, who's got the body panel? |
I got driver's side lower body panel from Bus Depot (kitchen rust repair) which worked out great for me. It has a fake seam where the rusted seam was but it blends in very well.
I also got this right rear wheel arch panel (made Klokkerholm) but ended up not using it. Seems pretty decent.
_________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown |
Bman Samba Member
Posted: Mon Jun 04, 2018 3:03 pm Post subject: Re: Panel, panel, who's got the body panel? |
Can someone explain what the issue is with the new panels available from the usual vendors? Seems like everyone is carrying panel parts, but they give very little information on the product.
What a variety on the price too, for the nose cowl, GW has it for $150, VC has it for $244 and BD carries it for $199. Again little info on whether this is NOS, aftermarket products or the thickness of said panels.
What is truly the differrence?
EDIT:
Doing some research here, as of a 2014 thread it appears the aftermarket panels avialble through our vendors may be from a Denmark Company called: Klokkerholm. Reports are that the sheet metal may be thinner. See here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
I have heard that VW Classic Parts no longer sell body panels, however the website is showing parts I need in stock. Try to checkout and you can not enter a USA address....so?
https://www.volkswagen-classic-parts.de/en/catalog...p;dir=desc
Perhaps back to rust free stock from donor vans... _________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl
calo1956 Samba Member
Joined: April 18, 2011 Posts: 703 Location: long Island new york
Posted: Mon Jun 04, 2018 9:51 am Post subject: Re: Panel, panel, who's got the body panel? |
I did the drivers side rocker panel from Bus Depot 4 or 5 yrs ago, it was good quality, and has been in only primer to this day. Fit was good, and it eliminates the one factory seam. _________________ Enjoy the ride....
72 bug
80 westfalia |
Bman Samba Member
ng Samba Member
Joined: October 01, 2011 Posts: 116 Location: Edmonton, AB
Posted: Fri Jun 01, 2018 4:29 pm Post subject: Re: Panel, panel, who's got the body panel? |
I notice you are in Vancouver, have you tried checking with Barry at Werke1
http://www.werke1.com/index.php
He supplies parts from a lot of vendors, handling the import and selling in CDN dollars. He also does a lot of really nice bodywork/paint, I'm guessing he knows what's up with panels. _________________ 1986 Syncro Westy "Braunbaer"
http://www.thesamba.com/vw/forum/viewtopic.php?t=607112 |
Posted: Fri Jun 01, 2018 2:16 pm Post subject: Re: Panel, panel, who's got the body panel? |
Thanks bobbyblack
I have contacted the Brickworks https://www.brickwerks.co.uk/ by email asking about panels and if the have a North American distributor (one could hope).
Does anyone know of a vendor of equal quality in North America?
Has anyone tried the GoWesty product? |
Bman Samba Member
Posted: Fri Jun 01, 2018 9:08 am Post subject: Re: Panel Panel whose got the Body Panel |
I generally look for rust free stock panels from part vans. In fact I'm driving 4 hours accross the state tomorrow to go plasma cut a driver's side rear quarter section for my syncro.
I have used stock cuts for nose repairs on my Westy before.....when Classic VW parts were selling I was fortunate to be able to buy all the OEM metal I needed for my Doka restoration (roof, drop gates, door and rear cab back). _________________ ~Bryan
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Fri Jun 01, 2018 7:31 am Post subject: Re: Panel Panel whose got the Body Panel |
The inexpensive panels that CIP1.com and others sell get consistently poor reviews around here, but I provided a couple to my bodywork guy and he did a nice job just using necessary sections of them. Not concourse quality, but solid as a rock:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100
_________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Fri Jun 01, 2018 7:08 am Post subject: Re: Panel Panel whose got the Body Panel |
I have some metal from a couple different dist's, and I have found that the best looking stuff I have has come from https://www.brickwerks.co.uk/ in UK. Hands down, top notch stuff. Worth paying for the metal, and the shipping. Widest selection too, from memory. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu May 31, 2018 10:34 pm Post subject: Panel, panel, who's got the body panel? |
I have been going through as many threads as possible trying to figure out if I should be replacing panels like the rocker panel drivers side on my 88 Westy or go the cut weld and grind route.
I noticed that there was a diverse range of opinions about using panels and sheet metal made for the purpose.
Where it gets really confusing is who the vendors are, and which manufacturers would be best.
I have phrased things this way because I have noticed that there are different sellers handling the same body panels from the same manufacturer at different pricing. Often the manufacturer may sell direct.
I would hope that I could get info on quality. I have seen on some posts that say some panels are so thin, that you may be back replacing them in a few years but also, there are some of very high quality with great fit.
With no previous experience, this is all very confusing. Is there a generally acknowledged high quality panel maker? Or, a best “budget” panel?
The internet has many many vendors and alleged makers, but my hope is to draw on actual experiences of forum members who have bought and used body panels.
I also noted that some panels are "large" panels and others are just pieces like the original ones.
To keep things simple, I would hope to focus just on the body panels as opposed to various body work techniques.
Thanks for helping |
