jiffysea Samba Member
Posted: Fri Jun 01, 2018 7:22 pm Post subject: 0.01 amps out of all 12v Outlets |
What would cause me to be getting 13.2v but 0.01amps. Is that a correct reading? I'm getting that reading with two different measuring devices so I assume it's accurate.
I also assume it's accurate because I'm having a really hard time getting things to charge on these.
Any ideas on where to start? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Fri Jun 01, 2018 7:46 pm Post subject: Re: 0.01 amps out of all 12v Outlets |
Post a picture of your measurements. Hopefully you didn’t measure amps by changing to the ammeter scale on your meter, you need to change the leads To be in series with the load. _________________ .ssS! |
Posted: Fri Jun 01, 2018 9:45 pm Post subject: Re: 0.01 amps out of all 12v Outlets |
I should have mentioned I wasn't using standard multimeter because that's what I would have asked someone else with the same question.
I'm using a socket multimeter but also perhaps more reliable, the charge controller panel on my battery system. They say I should be seeing between 2 and 10 amps off of a 12v outlet.
Camp is set up for the night so I'll only post pictures of the socket meter plugged into the dash socket but I did test all the rear ones earlier and they all read the same. Also, I checked and for good measure, have changed the fuses.
Posted: Sat Jun 02, 2018 2:32 am Post subject: Re: 0.01 amps out of all 12v Outlets |
What load is on the plug?
A cell phone should pull about 400 mA in charge mode, but it will go to zero when full.
A cheap device current error will be more than 10 mA, too. _________________ .ssS! |
Posted: Sat Jun 02, 2018 1:02 pm Post subject: Re: 0.01 amps out of all 12v Outlets |
Thanks for the reply. I'm not sure what's going on. I woke up this morning, fired up the van and turned on the battery and it indicated 8amps and was charging. Sweet! I thought. Just needed to sleep on that.
I plugged in the socket multi-meter thingy (it's the one available from GoWesty) and it too showed positive current.
Then.... about an hour later, everything zeroed out again. Charge controller says no amp input and socket multi-meter also says nothing.
I'm really new at some of this but that sounds like the Alternator, right?
s |
Zeitgeist 13 Samba Member
Posted: Sat Jun 02, 2018 1:07 pm Post subject: Re: 0.01 amps out of all 12v Outlets |
Have you checked the rear cargo area outlets AND the front dash outlet? I believe the latter runs off of the drivetrain battery and the former off of the house battery. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sat Jun 02, 2018 2:59 pm Post subject: Re: 0.01 amps out of all 12v Outlets |
There is no house battery currently. It's been pulled. And I did try the charging system in one of the rear sockets and I tried the socket multi-meter in two of three. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Sun Jun 03, 2018 9:33 am Post subject: Re: 0.01 amps out of all 12v Outlets |
The only current your "socket multimeter" can measure is the current drawn by whatever device is plugged into the USB port(s). Ammeters only can measure current in series with a circuit; it cannot tell you anything about the current of any other circuit in the vehicle parallel to the circuit you are measuring (such as the alternator).
If there are no USB devices plugged into it, it should indicate 0 amps...if it indicates anything other 0 amps, the reading is erroneous and should be ignored. It will tell you absolutely nothing about how the alternator is functioning (and hopefully nobody suggested to you that it would...). _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
