keary_lewis0303 Samba Member
Joined: March 18, 2003 Posts: 98 Location: St Petersburg FL
Posted: Sat Jun 02, 2018 5:54 am Post subject: Smaller pulley question |
I bought this engine with a smaller than normal pulley, it came off of a rail buggy. I'm putting it into a bug is this a good or bad thing. What's the purpose of a smaller pulley ? Will it create a cooling issue?thanks
Joined: August 31, 2013 Posts: 12860 Location: North Carolina
Posted: Sat Jun 02, 2018 7:22 am Post subject: Re: Smaller pulley question |
Those are called "power pulleys", they reduce the drag/RPMs by turning the generator/cooling fan slower, OK for quick passes down the strip, not so good for engine longevity. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
bluebus86 Banned
Posted: Sat Jun 02, 2018 8:44 am Post subject: Re: Smaller pulley question |
The small pulley is for decreased cooling, increased power output, what could go wrong? Its better use is as a paper weight.
Bug On in Coolness! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
mukluk Samba Member
Posted: Sat Jun 02, 2018 1:20 pm Post subject: Re: Smaller pulley question |
And just in case the message isn't clear yet that running a power pulley isn't a good idea for cooling and longevity reasons, the following pics are of an engine I was given showing what a power pulley is good for.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat Jun 02, 2018 4:30 pm Post subject: Re: Smaller pulley question |
Ouch i better get that outta there. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Jun 03, 2018 6:02 am Post subject: Re: Smaller pulley question |
Look at it this way...not using the thermostat? Using a power pulley will get the operating temperature up enough to vaporize the moisture in the oil. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
