Fan shroud "control flaps"
gintaras
gintaras is offline
PostPosted: Mon Jun 25, 2018 11:21 pm    Post subject: Fan shroud "control flaps" Reply with quote
I couldn't find any topics that cover these flaps, I did find a link on ratwell..
http://www.ratwell.com/dotmac/Pictures/Heating/10-FanShroudFlaps.jpg
Does anyone know where I can get these? I am missing one, the larger one..
I sent this engine off to someone for a rebuild, and I just didn't think to remove my shroud, and when it came back, that larger flap was missing...
1979 Deluxe Westy in Mexico Beige
ivwshane
ivwshane is offline
PostPosted: Tue Jun 26, 2018 2:10 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=1620194
I bought my set from a member here named whip but he doesn't have an ad up right now.
I believe German supply also has these.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
CrRusty
CrRusty is offline
PostPosted: Tue Jun 26, 2018 2:48 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
Do a search for:
VWC-021-119-263-APR
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jun 26, 2018 6:57 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
Phil makes them. Whip618
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
jtauxe Premium Member
jtauxe is offline
PostPosted: Tue Jun 26, 2018 7:01 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
There was just a thread that mentioned this a couple of months ago. I posted that I had made some from aluminum pie tins, and that someone was making them aftermarket.
https://www.thesamba.com/vw/forum/viewtopic.php?t=700300&highlight=
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
hazetguy
hazetguy is offline
PostPosted: Tue Jun 26, 2018 7:04 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
Who? Link?
sad to say, as I've had good dealings with them in the past, but just not interested in buying them from germansupply.
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
gadgetbec
gadgetbec is offline
PostPosted: Sun Mar 22, 2020 11:20 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
I found them online here, although I haven't tried them yet
https://www.csp-shop.com/en/engine/fan-shroud-air-flaps-119-263-021a-29611a.html
malcolm2
malcolm2 is offline
PostPosted: Mon Mar 23, 2020 7:02 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
IIRC there is a seal of some kind, maybe foam that sits on the edge.
I do remember that it is easy to pinch them between the fan housing and the heater box, so assemble everything and then make sure them open.... Very Happy
My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
Wildthings
Wildthings is offline
PostPosted: Mon Mar 23, 2020 11:30 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
When working correctly these check valves only come into play when the engine is not running, when the engine is running the valves are open and provide no function and might as well not be there. When not working correctly which is all too common they can block the fan shroud outlet(s) or break off and block the inlet into the heat exchangers.
Bugster78
Bugster78 is offline
PostPosted: Tue Dec 13, 2022 2:54 pm    Post subject: Re: Fan shroud "control flaps" Reply with quote
Can anyone provide the dimensions of these flaps so I can make my own??
ev_vw_dreams
ev_vw_dreams is offline
PostPosted: Tue Dec 13, 2022 3:57 pm    Post subject: Re: Fan shroud "control flaps" Reply with quote
I got a pair used from Ken at Busco. Reasonably priced
1979 FI CA bus
First time VW'er
SGKent is offline
PostPosted: Tue Dec 13, 2022 4:07 pm    Post subject: Re: Fan shroud "control flaps" Reply with quote
you really need a sample as it more than a simple set of bends. I believe that Phil made a die that he had them made with, then he sold a bunch 10 years ago or so.
originals
Ones Phil made about 2008
sebgi1
sebgi1 is offline
PostPosted: Tue Dec 13, 2022 4:49 pm    Post subject: Re: Fan shroud "control flaps" Reply with quote
I made mine with a 1/8 Masonite sample: cut a square hole about the dimensions you need and a piece to press in about maybe 1/16 inch less all around.
Put your aluminium tin between the two templates and press them with a c-clamp an a backing block. Keep some material all around to roll the hinges then cut to size.
Couples tries to make the right dimensions based on the flap end on the shroud.
Beer can or other small aluminium containers should do it.
I made mine with insulation tin from old heater boxes.
SEB
Dogs are the most precious and valuable possession of mankind. VWs are second!
'73 Neptune blue safare camper
'71 Neptune blue tintop
Willin
Willin is offline
PostPosted: Wed Dec 14, 2022 8:34 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
I made mine from a license plate. I had old, broken ones for pattern. Mine are flat. Used my shop vac. to make sure they operate. Suck, or blow, from one side of shroud, then the other. You can hear them slap open or closed. Read here recently the foam seal was more to keep them from rattling. I didn't use any seal, but I imagine just a thin layer of silicone would work.
Bleyseng
Bleyseng is offline
PostPosted: Wed Dec 14, 2022 10:12 am    Post subject: Re: Fan shroud "control flaps" Reply with quote
You can buy them here:https://914rubber.com/pressed-air-intake-flaps-wfoam-1
They were installed to stop the aux fans from blowing air into the fan housing at idle so you blow the air from the aux fan through the heat exchangers for heat/defrost. Yes, they did have a small foam seal on the edges originally to make a seal. $35 is pretty cheap for a nice set that work correctly.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
