msewalson Samba Member
Joined: September 14, 2009 Posts: 544 Location: Grand Junction, Colorado
Posted: Sat Jun 02, 2018 12:09 pm Post subject: Custom kitchen galley cabinet with Truck Fridge and Espar |
Figure I would share my recent build with the samba group.
To start off this was our old set up that I built in 2015. Overall it worked great but the down side for us was the big chest style fridge, not pictured. It took up way to much floor space.
I decide to go with a truck fridge which required a new cabinet be built. This also meant a new cook top would be needed. I went with a SMVE combo unit and sourced it from the UK. I purchased it off of eBay and was a little hesitant not knowing if I would need to pay a bunch of import fees. In the end I never had to and the total cost including shipping was much cheaper than purchasing it in the States.
Here’s a view of the cook top I used.
I also redid the floor too. I purchased a garage floor rubber off of Amazon and glued it to a 1/2” piece of Baltic Birch. The exposed end by the slider is built up to 3/4” and rounded over so I could wrap it with the rubber. The floor is secured using t nuts imbedded into the flooring and secured from the bottom through existing seat mounts.
I also installed an Espar B1LC under the Fridge. I sourced the unit from Esparparts.com. I went with the high altitude fuel pump since it will be used mostly at higher elevations. I used a mounting plate that I sourced from heatso.com that made installing it in the corrugated floor much easier.
Routing the intake and exhaust was pretty straight forward.
I did have trouble locating the needed brass fitting for running the fuel supply line. I ended up purchasing them off the internet.
Initially I had a little leak at the fuel pump but switched out a fitting to get it all tighten up.
I also added a 5 gal fresh water tank and GoWesty camper hook ups. I went with the water fill, 110V and solar plug. The 110v is only for a GFI plug that the fridge is plugged into. The solar plug is for our portable solar panel that I put out when at camp.
Overall I’m really happy with this setup but have a few things I would like to change.
Matt _________________ 87 Syncro w/EJ22 |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Sat Jun 02, 2018 12:19 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Nice setup, looks good. Great work! _________________ Currently:
jimf909 Samba Member
Posted: Sat Jun 02, 2018 12:46 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Super sweet!
Is the cooktop incorporated in the lid that covers the sink? Is it an induction type?
Edit: does the drying rack move to reveal the burner? _________________ - Jim
Abscate wrote: |
Love My Westy Samba Member
Posted: Sat Jun 02, 2018 12:56 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
I saw it at Syncro Solstice. What a nice van! Matt always does a great job. |
Posted: Sat Jun 02, 2018 1:20 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
jimf909 wrote: |
Super sweet!
Edit: does the drying rack move to reveal the burner? |
The drying rack is removable and a single burner is located under it.
Posted: Sat Jun 02, 2018 1:21 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Love My Westy wrote: |
Thanks for the compliment Rich. It was nice visiting with you at Syncro Solstice. See you next year!
llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Sat Jun 02, 2018 1:41 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Very clean work. Little details like wrapping the end of the floor make the difference.
I also like the rails to protect the drive shaft. What are the three balls? I was maybe something to do with sir suspension?
Again, compliments. _________________ 87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present) |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Sat Jun 02, 2018 1:57 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
llilibel03 wrote: |
Again, compliments. |
Stock Syncro bits, the three ball thing is the vacuum reserve tank for the diff lock. _________________ Currently:
Posted: Sat Jun 02, 2018 2:15 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
MsTaboo wrote: |
llilibel03 wrote: |
Stock Syncro bits, the three ball thing is the vacuum reserve tank for the diff lock. |
I guess I never really crawled around under my syncro when I had it. _________________ 87 syncro tintop
90 gl tin top
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
Posted: Sun Jun 03, 2018 11:40 am Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Rock solid job! I’m a builder and cabinet maker and you can plainly see that you know what you’re doing. I like the choice of Baltic birch for the cabinets also. It’s a very clean look. Well thought out and executed. Congrats on a great build. The espar is one of my favorite additions to my van. It’s luxurious to be able to camp with a cabin heater. Again, great job! |
Posted: Sun Jun 03, 2018 12:04 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
dobryan wrote: |
Matt is a craftsman for sure. |
Thanks Dave. How did your trip go with your son?
Posted: Sun Jun 03, 2018 12:23 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Multiman mv wrote: |
Thank you for the kind words. My wife actually gave me a hard time since my time frame was longer than normal. I decide to go with a Euro style cabinet to maximize usable space. It took a while to come up with an overall layout and dimensions to provide need clearances for the Espar and cooktop. I do like working with Baltic Birch especially with frameless cabinets since the exposed edges finish off nicely. The construction was pretty easy, I’m a Festool guy and love my track saw, domino cutter and MFT table.
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Sun Jun 03, 2018 1:35 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Really nice build!
Can you tell me what the pulls are you used? Always looking for options myself.
Thanks
Brian _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
Posted: Sun Jun 03, 2018 6:40 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
bjrogers86auto wrote: |
Really nice build!
Thanks
Brian |
Manufacturer is Southco. _________________ 87 Syncro w/EJ22 |
Posted: Sun Jun 03, 2018 6:49 pm Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
dobryan wrote: |
msewalson wrote: |
dobryan wrote: |
Matt |
We fly to Denver June 22 and pick up the bus to start our trip. I’ll update the original thread with the trip. |
Have fun and safe travels Dave. Give me a ring if your passing thru Grand Junction. _________________ 87 Syncro w/EJ22 |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Jun 04, 2018 8:39 am Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Can you post a link or part# for the water tank? |
Posted: Mon Jun 04, 2018 9:00 am Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
Steve Arndt wrote: |
I bought it locally. Here's a link to their website and the one I purchased.
http://bobscottrv.viaretailparts.com/10-1640
Posted: Mon Jun 04, 2018 9:22 am Post subject: Re: Custom kitchen galley cabinet with Truck Fridge and Espar |
How did you plumb it? What pump did you use? |
