hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Jun 02, 2018 8:55 pm Post subject: Evaporative Shop Coolers- Opinions? |
Hello folks-
I'm spoiled at my work in our shop with a huge Portacool. It is the largest they make- and cools about 4000sqft of shop very well- save for the noise. My subject is what do folks use for their home shop. I've got about 700ft in my main work area of my detached garage. I also host the occasional patio thing that roasts grandparents and melts homemade ice cream before its eaten. I'm investigating portable coolers (Portacool models in particular in the 110v, 16" and smaller range and they run about $800-1000 on their website) and really want to know what other folks use.
Are there rival companies folks love I should check?
PS- There's one other "cooler" thread- but the subject switches between thermadors and swamps with no clarity. _________________
EverettB wrote: |
FU#5 |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sun Jun 03, 2018 3:32 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
How much humidity is normal for your region? If you live in a region with “dry heat” then a swamp cooler will work for you. In my area, the humidity level is usually 90% or more (currently 97%). When the air is already this thick, an evaporative cooler doesn’t work.
Unless you want to dump a large amount of money into a hulking appliance that you might only use 3-4 times a year, you can invest in a large awning, buy misting nozzles
https://www.aeromist.com/misting-nozzles.html
& a few box fans/squirrel cage blowers & cool a much larger area. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Sun Jun 03, 2018 4:40 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
I use a 10,000 BTU window AC unit in my 2 car garage. It works good on days when it is 95 or hotter it keeps it at around 75 also keeps the humidity down. They are only 270.00 and does not take up floor space. |
gt1953 Samba Member
Posted: Sun Jun 03, 2018 5:25 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
I like the idea of the portable cooler as you can use it for other applications. I think you are in a dry low humidity region. Go for it. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Jun 03, 2018 9:57 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
Boise Idaho is often near triple digits temps in the summer, with near single digit humidity. Swamp coolers work very well there.
Bradford, I have no experience with the particular brand of cooler you mention, but they seem to work. For your shop, a permanent swamp cooler would likely do well. For outside, the recommendation of misters and fans might be better. _________________ nothing |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Sun Jun 03, 2018 10:38 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
hitest wrote: |
I also host the occasional patio thing that roasts grandparents and melts homemade ice cream before its eaten. |
The first time I read it I was trying to imagine what roasted grandparents taste like. |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Sun Jun 03, 2018 12:00 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
I'm interested too in suggestions. Where I live, it's often 95 and 95 percent humidity. I have fans but they blow hot air. The shop gets hotter than that and I have two ceiling fans also _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
Posted: Sun Jun 03, 2018 1:14 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
bigdog1962 wrote: |
I'm interested too in suggestions. Where I live, it's often 95 and 95 percent humidity. I have fans but they blow hot air. The shop gets hotter than that and I have two ceiling fans also |
Think of it as getting into a car that has had standing water in the floorboards after it has been sitting in your shop, it’s even more stagnant.
Evaporative cooling only works if the air isn’t already at maximum saturation. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Jun 03, 2018 1:41 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
TDCTDI wrote: |
bigdog1962 wrote: |
Evaporative cooling only works if the air isn’t already at maximum saturation. |
Yep, just like sweat. In Georgia, sweating doesn't cool you much. In Arizona, you can't sweat enough to keep up. _________________ nothing |
hitest Samba Member
Posted: Sun Jun 03, 2018 3:58 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
cdennisg wrote: |
Bradford, I have no experience with the particular brand of cooler you mention, but they seem to work. For your shop, a permanent swamp cooler would likely do well. For outside, the recommendation of misters and fans might be better. |
I unfortunately need something portable- as I move around a lot and the ergonomics (messes) in my garage seem to always change where I'm wrenching or drinking. I suspect anything will work well- even the smaller Honeywell units from Costco. But holy cow, that Portacool is sweet. Id rather have one I need to turn down from time to time than one that must always work at max capacity. It's 87 here today- and I already want to flee my garage. _________________
EverettB wrote: |
FU#5 |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sun Jun 03, 2018 4:46 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
I have the biggest window unit before you go to 220....I think it's a 15,000 BTU (would have to check)
it cools my 4 bay shop with 14' ceilings no problem and that's bringing cars in/out multiple times a day.
averages 70* in here during the day. 65* if I have a car in all day and don't open the door. it's nice to work with your bean bag not sticking to your leg _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
busdaddy Samba Member
Posted: Sun Jun 03, 2018 5:43 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
hitest wrote: |
....16" and smaller range and they run about $800-1000 on their website) ........ |
Sounds like it's time for a trip to Harbor freight for one of those big drum fans and a small water pump, not sure where you would find the coconut matting or whatever they use now for the wicking surface, maybe your local A/C service guy knows? An underbed storage tote for a water tank and some creative pop riveting and duct taping of some flashing or sheet metal for the shroud could come up with a similar rig, those Portacools look sweet, but there's not much science involved in them that you can't duplicate at home. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hitest Samba Member
Posted: Sun Jun 03, 2018 8:01 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
Yup- they are bloody expensive. I still do want something slick and safe enough that my wife can roll it around the porch. Portacool has a little bit of that extra name-recog. value in them. But when they approach the price of whole cars... _________________
EverettB wrote: |
FU#5 |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Jun 04, 2018 9:54 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
You could install a mini split system and also get heat in the winter.
hitest Samba Member
Posted: Mon Jun 04, 2018 2:53 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
Thanks toolbox- fortunately I've already got a small NG heater in the ceiling- along with a large overhead fan. _________________
EverettB wrote: |
FU#5 |
Mid Engine Bug Samba Member
Posted: Mon Jun 04, 2018 2:55 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
I have a little portable AC unit like this...
https://www.homedepot.com/p/Haier-8-000-BTU-Portab.../300013684
It works ok for the garage but I believe thats mostly my garages fault. There is a big lack of insulation. When one of my AC units for the house went out, I used the portable unit inside and it worked good. The room I had it in is about the size of a 4 car garage and it kept the room at around 80° when it was 100° out. The thing that I dont like about it is that there is a big duct that you have to run outside. There is also a water drain line that needs to go outside. _________________ 1970 Bug Shell - the rest of it, well see for yourself...
https://www.thesamba.com/vw/forum/viewtopic.php?t=679467 |
hitest Samba Member
Posted: Tue Jun 05, 2018 8:11 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
Hmmm. Hadn't thought of one of those for the porch- excellent outdoor application. Thanks for the tip! _________________
EverettB wrote: |
FU#5 |
Spezialist Banned
Posted: Fri Jun 08, 2018 11:50 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
It’s the right way to cool. Adds moisture to the air which helps your body cool also. _________________
Abscate Samba Member
Posted: Mon Jun 11, 2018 11:22 am Post subject: Re: Evaporative Shop Coolers- Opinions? |
Quote: |
t's nice to work with your bean bag not sticking to your leg |
Its my knee for me _________________ .ssS! |
Posted: Mon Jun 11, 2018 12:08 pm Post subject: Re: Evaporative Shop Coolers- Opinions? |
Spezialist wrote: |
It’s the right way to cool. Adds moisture to the air which helps your body cool also. |
Only if you're in a dry climate. If it's 90% humidity or more, the body's natural evaporative cooling system only leads to swamp-ass, adding more moisture to the air doesn't help. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
