Dubdealer Samba Member
Posted: Tue Jun 05, 2018 5:24 pm Post subject: Vin number? Notchback |
Looking to buy a notchback and have a question about the vin. It starts with 365 and on here in the vin section it says that should be a 65 sqaureback. Is this correct? Any help would be appreciated. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Jun 05, 2018 5:46 pm Post subject: Re: Vin number? Notchback |
A VIN beginning with 365 would be a 65 Squareback |
Posted: Tue Jun 05, 2018 6:20 pm Post subject: Re: Vin number? Notchback |
I know it says 365 is a squareback in the vin section, but what should a notch start with? The pan vin is not tampered with and the tag plate in the front doesn’t look like anyone changed the rivets or signs of the sheet metal welded.has anyone seen a notch vin starting with 365? |
Posted: Tue Jun 05, 2018 6:50 pm Post subject: Re: Vin number? Notchback |
Dubdealer wrote: |
A Notchback VIN will not start with 365. The "36x" indicates that it's a Variant/Squareback. You'd see a "31x" for either the Notchback starting with the 1965 model year or Fastback starting with the 1966 model year.
The numbering system changes in 71 and adds a number but that doesn't apply to a pre 69 model year car.
The pan could have been swapped to a Notch - it's not hard to do.
Additional information:
https://www.thesamba.com/vw/archives/info/modelstype3.php
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Tue Jun 05, 2018 6:52 pm Post subject: Re: Vin number? Notchback |
Never thunked about it, so had to check, my 65 notch is 365 starting number _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Jun 05, 2018 8:59 pm Post subject: Re: Vin number? Notchback |
I have looked at all of vin info in the technical category but trying to make sure about this and educate myself before buying this notch. Is there a difference in weight on the front plate for squareback compared to notch? Also when did they stop the push button dash? |
Posted: Tue Jun 05, 2018 9:19 pm Post subject: Re: Vin number? Notchback |
Posted: Wed Jun 06, 2018 9:00 am Post subject: Re: Vin number? Notchback |
Dubdealer wrote: |
April 1964 is when the press button (aka: pushbutton assembly) was discontinued. Specifically, the last VIN was 423 139
If the VIN shows "365", it was originally a Squareback pan. Quite common for pans to be swapped. The rear seat area kick panel is a little different between Notch and Squareback - perhaps post up a picture of that area to confirm it's a Squareback pan if the VIN isn't convincing you. |
Posted: Wed Jun 06, 2018 9:47 am Post subject: Re: Vin number? Notchback |
ataraxia wrote: |
Dubdealer wrote: |
Thank you Ataraxia! |
Posted: Wed Jun 06, 2018 10:01 am Post subject: Re: Vin number? Notchback |
Posted: Wed Jun 06, 2018 10:05 am Post subject: Re: Vin number? Notchback |
I see the pan has hinges for a squareback folding back seat! I learned something today! Thanks ataraxia! |
Posted: Wed Jun 06, 2018 10:10 am Post subject: Re: Vin number? Notchback |
Dubdealer wrote: |
That's specifically what I was looking for in the pic request. Squareback rear seat hinges are different as are the support brackets.
The rear subframe is reinforced on the Squareback and the torsion bars are slightly larger in diameter. Have a picture of the subframe (the bottom of it between the axles)? |
Posted: Wed Jun 06, 2018 11:07 am Post subject: Re: Vin number? Notchback |
ataraxia wrote: |
Dubdealer wrote: |
No I don’t have anymore pics. Would love to see one and know the difference. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
