vamram Samba Member
Posted: Sat Mar 05, 2022 1:02 pm Post subject: Re: '73 Super Salvage Project |
Thanks for that link Buggee. The thing started working again but is obviously off. I broke down and bought a replacement from one of the samba Speedo rebuilders. I may try rebuilding this one myself after but don't trust myself to not f*k it up. I bought a known bad one a couple years ago to try my hand at rebuilding it....this did not end well. I need this Buggy operational so I bit the bullet.
On another note, for shits n grins I reinstalled the eBay Chinesium carb from a few pages back for my trip back north...runs and idles super smooth, and, if I'm to believe the Waze GPS, I got 32+ MPG between Miami and Sanford. Pretty damn good. time will tell how long the carb will last.
Speaking of "normal" wear on a daily driver,Once back in VA, it's time to replace the front brake pads and inspect the rears. Shoes look good thru the adjusting star holes but in my experience the shoes wear much more at the top half. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sun Mar 13, 2022 4:04 pm Post subject: Re: '73 Super Salvage Project |
So 18.5k (Give or take....??) I decided it was time for new front brake pads.
This was so easy to do I'm tempted to do a rear disc conversion, even though there's really no need for them on this 1600DP monster. Old pads.
Nice and meaty new ones. I reused the pins and springs.
I may need to replace or rebuild the left caliper though. The right side pads were evenly worn and down to about 3mm. The driver side however were 2x as fat, frankly didn't even need to be changed but I did it anyway. I had never noticed any issue w/the braking, but paid closer attention during the post-change test drive and there's definitely a slight pull to the right.
Perhaps they just need to be bled? Or rebuilt? I've never rebuilt one of these before, may be time for a new learning experience.
Funny, three days ago everyone in the neighborhood was thanking me for bring the hot weather w/me as the temps reached 80*. Today, it was 20* at 7 a.m. and my neighbors are asking why I bothered to come back! I too was asking myself this.
I have the replacement dash fan but did not get to that today, too cold. I also have a rebuilt speedo w/a known properly rebuilt odometer (per the seller), but again too cold to tackle that today. Enough w/the brakes. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Wed Mar 16, 2022 11:22 am Post subject: Re: '73 Super Salvage Project |
Got my birth certificate! Took less than a month!
Click to view image
Save the Supers!! |
sb001 Samba Member
Posted: Wed Mar 16, 2022 11:24 am Post subject: Re: '73 Super Salvage Project |
vamram wrote: |
Sweet! How much does this cost now? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
vamram Samba Member
Posted: Wed Mar 16, 2022 12:34 pm Post subject: Re: '73 Super Salvage Project |
Well.. it's a bit pricey, I think it was 129.00 Euros...but what the heck, I love this car and have put a lot into it, and ya only need the certificate once, right? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Wed Mar 16, 2022 3:56 pm Post subject: Re: '73 Super Salvage Project |
Installed the "New" rebuilt speedo. Always fun to do while keeping the connections correct holding two speedos up against each other, your arms and the steering column & dash while avoiding disconnecting wires while reaching almost blindly thru the various dash openings.
I should've had the restorer set it to 19k, since I had no odometer for the first two tankfulls of gas anyway.
I also think these old mechanical odometers are a toss up. The speedo is almost spot on for mph w/the GPS, but the odomoter read 5.0 miles on "5" mile test run while the GPS read 5.51. So...not as off as the old odometer, but guess I'll just have to live w/it.
The "new" gas gauge seems to work, zips right up to full where I left the tank a day ago. It is more active than the previous one in that it seems to fluctuate more readily w/the sloshing of the gas in the tank as I drive around turns and up and down hill.
Next on the maintenance list:
- replace the dash fan
- rebuild left front caliper (rebuild kit ordered from Topline today)
- replace bad right side hood hinge
- fix trunk hood nose - rust problem, will require cutting and welding a tip edge _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Mar 16, 2022 7:36 pm Post subject: Re: '73 Super Salvage Project |
Victor, my speedometer is right on, too, but my odometer is about 20% off. Very weird, especially since the unit is a VDO, bought new (yes, you could still buy new ones in the mid 2000’s) by the previous owner.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 613 Location: 253 Then, Now 206.
Posted: Wed Mar 16, 2022 8:31 pm Post subject: Re: '73 Super Salvage Project |
Tim Donahoe wrote: |
Tim |
Is it a tire size issue? Are you running stock tires?
Seems like both would be off, but who knows... _________________ 1970 Beetle | Basically Stock 1600 SP |
vamram Samba Member
Posted: Thu Mar 17, 2022 4:32 am Post subject: Re: '73 Super Salvage Project |
165/80/15, nexen SB802. Front at 22psi, rear 28. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Thu Mar 17, 2022 9:49 am Post subject: Re: '73 Super Salvage Project |
I also run the same size tires as a Vamram, and, weird as it seems, the odometer reading is, in fact, inaccurate; however, the speedometer is spot on. My VDO is stock, but a brand new (when it was purchased) replacement for the original.
Richard O'Brien |
vamram Samba Member
Posted: Mon Mar 21, 2022 5:00 am Post subject: Re: '73 Super Salvage Project |
I've given up on odometer accuracy at this point. I suppose I could go crazy and put 155/r15 Bias ply tires on it...but nope.
Moving on to the daily driver update. Yesterday I flushed the brake system, replacing the fluid by bleeding all four corners. After two years, the rear wasn't too discolored, the fronts much more so. I guess that's due to most of the braking happing w/the front disc brakes. Anyway, great pedal, stops on a dime. I also received the caliper rebuild kit from topline. Maybe later this week I'll take a crack at that. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sat Apr 16, 2022 12:24 pm Post subject: Re: '73 Super Salvage Project |
Crappy day at the supermarket parking lot.
Click to view image
Save the Supers!! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Apr 16, 2022 12:51 pm Post subject: Re: '73 Super Salvage Project |
That sucks. Sorry man.
I can see the fender and bumper have damage. Any inner wheel housing buckling? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
vamram Samba Member
Posted: Sat Apr 16, 2022 1:24 pm Post subject: Re: '73 Super Salvage Project |
Apron looks fine. Might have to straighten the bracket. I think I can get it mostly out, then I'll take it to the same guy who painted it. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sat Apr 16, 2022 1:41 pm Post subject: Re: '73 Super Salvage Project |
EZ PZ! You could also just take the fender to them. Just a thought. _________________ Jimbo
TDCTDI wrote: |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 447 Location: Rhode Island
Posted: Sat Apr 16, 2022 2:55 pm Post subject: Re: '73 Super Salvage Project |
Oh no, what a shame. You have my sympathy. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Maddel Samba Member
Posted: Sat Apr 16, 2022 11:43 pm Post subject: Re: '73 Super Salvage Project |
vamram wrote: |
Crappy day at the supermarket parking lot. |
vamram Samba Member
Posted: Sun Apr 17, 2022 6:06 pm Post subject: Re: '73 Super Salvage Project |
Managed to pop out most of the dent. I have to remove the bumper to complete the rest - pull the fender forward to try to eliminate the slight kink at the top of the curve, where the blue arrow points, and tap tap tap w/a hammer to pop out the small remaining dent where the red arrow is. This one was not very responsive to the rubber mallet I used and I didn't want to hit it w/the body hammer until I have time to completely remove the fender and replace the wrinkled bracket.
Click to view image
Save the Supers!! |
Posted: Sun Apr 17, 2022 10:44 pm Post subject: Re: '73 Super Salvage Project |
So, it was a hit and run?
Richard O'Brien |
vamram Samba Member
Posted: Mon Apr 18, 2022 4:37 am Post subject: Re: '73 Super Salvage Project |
Yep, could've been at any number of places. I was running around to various supermarkets looking for last minute ingredients for wifey's menu (big list, lots of company, had to do my part...!) and didn't even notice is until later that day. Oh well. I'm just glad it wasn't worse. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
