ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Posted: Tue Jun 05, 2018 6:40 pm Post subject: Still battling sand seals |
Ive had little luck with my sand seal. I got a new one this spring since I didn’t drive it all last year and it was leaking again. I had luck for about a month until i took it for a 45 minute driveon the highway a week ago. During the drive I actually felt a change at one point and when i arrived at my destination oil was everywhere. Ive read as much as i can regarding the way a vw breathes, crankcase pressure, and the like. Ive applied that utilizing oil separators, one-way crankcase vents, and venting the valve covers, case and filler. I just checked compression and leak down both giving me no clues as to what problem i have. I’m running 1/2” hose from all my vents to a bugpack breather box and im about to try venting straight to the atmosphere on the filler or the case in hopes I just don’t have a big enough outlet. But im not very optimistic.
Just thinking Id throw this out there in case anyone else has had similar troubles and found a fix. I’m about ready to rebuild the cylinders and possibly the heads in hopes its blowby that isnt showing in my tests. If i do this is it for the bug this year since i have no shop to work in at the moment. I just want to drive the thing a bit for petes sake. Not asking to offroad or anything crazy. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Wed Jun 06, 2018 7:16 pm Post subject: Re: Still battling sand seals |
Well after draining about a quart of oil thru the oil filter thinking maybe i had filled it to full i ran to the gas station and oil is everywhere and literally pouring from the seal AT IDLE! I’m gonna try going back to a stock pulley and loose the seal. Too bad I don’t have the stocker in my bins of parts.
If oil is coming out this quick at idle and the engine runs good im thinking crankcase pressure is not my problem. I would be noticing air movement at the vents. However, i was recently told the seal is to keep dirt out not oil in so im still baffled. Maybe it’s time for a new engine? _________________ Brian H.
Dark Earth Samba Member
Posted: Wed Jun 06, 2018 7:42 pm Post subject: Re: Still battling sand seals |
Have you seen this ??
http://www.vw-resource.com/crankcase_ventilation.html
I would either get a stock pulley with grooves and run a hose to the carburetor air cleaner or find a different non grooved pulley to run with the sand seal. _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Thu Jun 07, 2018 6:04 am Post subject: Re: Still battling sand seals |
Could it be possible that the oil return groove is clogged? I have seen this with people who misuse rtv silicone sealant. If it is blocked, the pressure of the oil being pushed out of the bearing will have to go somewhere, and if the oil return groove is really plugged up, the next path of least resistance would be for the oil to push past the sand seal. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
turbo2387 Samba Member
Joined: January 29, 2018 Posts: 44 Location: Pendleton, IN
Posted: Thu Jun 07, 2018 6:42 am Post subject: Re: Still battling sand seals |
is it a quality pulley and its matching seal? |
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Posted: Wed Jun 13, 2018 5:46 am Post subject: Re: Still battling sand seals |
Went back to stock pulley and leaks have dwindled. Haven’t run long enough to be sure. When i took the sand seal out the seal had separated from the carrier which seems to happen a lot if you dont use sealant between the two. That obviously was the culprit this time. Wondering if i need to shim the pulley a bit to back it off from the seal so its not creating friction and making it grab the seal. Perhaps when i get back into off-roading ill guve that a try. For now i need to rejet. Seems this change has made some kind of difference in the way it runs, or my rings are about to give up lol.
Hope this helps someone down the line. _________________ Brian H.
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Jun 13, 2018 6:20 am Post subject: Re: Still battling sand seals |
Are you running the spacer between the pulley and crank? The snout on the sand seal pulleys is actually shorter slightly than a stock pulley, so without the spacer the pulley face will ride against the face of the seal and cause issues. |
Posted: Thu Jun 14, 2018 7:12 pm Post subject: Re: Still battling sand seals |
That’s a good point and no I didn’t have a spacer, none was ever provided. The past couple days ive been having trouble getting off the highway and coming to an idle and having my oil pressure alarm going off. Not sure but i think the oil is getting warm enough its thinning and affecting the pressure. When i check it the level its fine. If i give it time to cool down it goes away or if i drive around town it doesn’t happen. I never had a cooling issue before i changed to the stock pulley. I traded one problem for another. And its still leaking especially if i fill it to the range on the dipstick. I’m worried ill blow the engine soon despite how well it runs otherwise. Ive been chasing this issue for so long im starting to think a new engine is my only solution. I really wish i new someone who understood these engines that could take look at it besides me. I’m no dummy but obviously my talents aren’t enough in this case. I need fresh eyes. _________________ Brian H.
Posted: Tue Jun 19, 2018 5:21 am Post subject: Re: Still battling sand seals |
Here is a pic from the CB Performance website. Note just below the seal there is what appears to be a large washer. That is the spacer that fits between the pulley and the case.
Posted: Mon Jun 25, 2018 6:03 am Post subject: Re: Still battling sand seals |
I ran into a crusty old guy at the steel yard who seemed like he understood my problem. He said the 1835 tends to have a lot of blow by and if i have a high pressure oil pump that will add to the problem as well. I do have an aftermarket pump with the filter but no idea what it puts out. _________________ Brian H.
Posted: Mon Jun 25, 2018 8:14 am Post subject: Re: Still battling sand seals |
ORANGECRUSHer wrote: |
I ran into a crusty old guy at the steel yard who seemed like he understood my problem. He said the 1835 tends to have a lot of blow by and if i have a high pressure oil pump that will add to the problem as well. I do have an aftermarket pump with the filter but no idea what it puts out. |
The only reason an 1835 would have excessive blow by would be if the thinner 92mm cylinder were warped. Most aftermarket pumps are 30mm, which is big by itself, but then coupled with thick oil will cause major issues with leaks. |
Posted: Mon Jun 25, 2018 6:08 pm Post subject: Re: Still battling sand seals |
I’m wondering about my cooling too. However I haven’t had tge oil light come on since that week i had that coming off the highway. I think my main jet was a little lean. Things have been ok. Im getting oil on my belly pan, but not to the degree thats alarming or flinging all over ruining my cool. So im driving it at least. Thanks for the support. _________________ Brian H.
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2238 Location: Medford, OR
Posted: Fri Jun 29, 2018 6:54 am Post subject: Re: Still battling sand seals |
Have you done compression check?
What’s the engine mileage? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
dustymojave Samba Member
Posted: Tue Jul 03, 2018 4:09 pm Post subject: Re: Still battling sand seals |
More important than a compression test, is a "leak-down test" to check for piston ring or valve guide blow-by. _________________ Richard
SoCalBajas Member
