rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Tue Jun 12, 2018 4:54 am Post subject: Re: Does this wiring look right for push button ign? |
So I ran this by a guy with an electrical engenering degree and he says why the relay? He said the sw/button can handle the starter current That got me thinking, the starter button is only momentary and isn’t used when wipers and horn etc are also sucking juice and all those devices that are on the 15/54 circuit to the switched 12v circuit can’t be drawing that much since the stock wire is pretty small
He told me this would work fine: Thoughts?
_________________ CHEAP - FAST - RELIABLE
You can only pick two of the above. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Tue Jun 12, 2018 5:36 am Post subject: Re: Does this wiring look right for push button ign? |
rrcade wrote: |
So I think this is what you mean:
'B' The LAPS sells 20amp toggle switches that have a built-in light. Simplify the circuit a little more. When you turn the toggle switch 'on' the handle lights up. With method 'B' the pushbutton can be rated as low as 1amp and the wire gauge can be 18 or even smaller. 12gauge isn't needed. Then again you may want a bigger target for the finger and a higher amp button will be bigger but it doesn't have to be 35amp. When you are connecting the pushbutton to a ground 'source' it could be the mounting of the button itself. That is if your panel is made of metal and mounted to the body. Take the wire and put a ring crimp that has a hole the size of the threaded part of the button and put the ring over it then put the button thru the panel and tighten up or under one of the panels mounting to the body screws one less wire to run. If you mount these switches in the dash all the wiring is made even simpler. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Fri Jun 15, 2018 4:25 am Post subject: Re: Does this wiring look right for push button ign? |
Sorry that I bailed on you, but you are in damn good hands....Been buried at the shop getting a car done for a customer that wants to take it to a show tomorrow. _________________ D-Dubya Manx clone - 63 Short pan,1914.
