Bleeding Front Brakes Only
Ray Syverson
Ray Syverson is offline
PostPosted: Wed Jun 06, 2018 12:32 pm    Post subject: Bleeding Front Brakes Only Reply with quote
Since it is a split system, separating the fronts and backs, is it ok to just bleed the front brakes after replacing the two front brake lines? Seems like it should be, but thought I should check. Thanks
Wildthings
Wildthings is offline
PostPosted: Thu Jun 07, 2018 12:32 am    Post subject: Re: Bleeding Front Brakes Only Reply with quote
Sure, but if you haven't done it in a while you should also bleed the rears to flush the old contaminated fluid out. Might as well keep the front and rear on the same flushing schedule.
Ray Syverson
PostPosted: Thu Jun 07, 2018 6:51 am    Post subject: Re: Bleeding Front Brakes Only Reply with quote
Thanks, I will be doing the rears in the near future,since I bought new brake lines for them also. Just wanted to know if I could split the job into two parts.
