How to unpin/ separate tail light wires from block
joosty_chin
joosty_chin is offline
PostPosted: Thu Jun 07, 2018 8:04 am    Post subject: How to unpin/ separate tail light wires from block Reply with quote
I am having a heck of a time trying to figure out how to remove the wires from the white connector block that connects the wiring harness in the engine bay to the tail light harness. How can I disconnect without cutting the wires?
vwwestyman
vwwestyman is offline
PostPosted: Thu Jun 07, 2018 12:11 pm    Post subject: Re: How to unpin/ separate tail light wires from block Reply with quote
There is a litttle tab that holds the terminal in the block.
Many times you can depress it with a strategically placed bent paper clip or similar. It can be tricky but if you push the wire in a little, that will prevent the tab from having friction against the block when you try to depress it with the paperclip. Then you can usually pull it straight out.
You can see a sample of the tab in this pic (it is most apparent in the middle image):
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
www.thefosterdads.com
joosty_chin
PostPosted: Thu Jun 07, 2018 2:17 pm    Post subject: Re: How to unpin/ separate tail light wires from block Reply with quote
I would've never figured it out. Ill try this!
Thanks!
Ron Domeck
Ron Domeck is offline
PostPosted: Thu Jun 07, 2018 3:59 pm    Post subject: Re: How to unpin/ separate tail light wires from block Reply with quote
We use a small screw driver that I ground down to fit.
vwwestyman
PostPosted: Thu Jun 07, 2018 4:42 pm    Post subject: Re: How to unpin/ separate tail light wires from block Reply with quote
That seems like a great idea! Sometimes the paperclip can be a little too "bendy" and makes it a bit more fiddly of a task than it probably needs to be.
Dave Cook
1973 Wild Westerner
My Thing
joosty_chin
PostPosted: Fri Jun 08, 2018 5:58 am    Post subject: Re: How to unpin/ separate tail light wires from block Reply with quote
Small screw driver for the win! Got it accomplished. Thanks fellas!
