jadlee Samba Member
Joined: December 27, 2017 Posts: 37 Location: Bloomington Indiana
Posted: Thu Jun 07, 2018 7:49 pm Post subject: Can a 1980 Rabbit engine (EJ code) go into 1988 Cabriolet? |
Will a 1980 Rabbit engine (EJ code) go into a 1988 Cabriolet? I'm pretty sure it's a straight swap, except for maybe radiator hose. Also with the external parts removed from engine how hard is it for two guys to pick up to put in a pick-up truck? |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Fri Jun 08, 2018 3:50 am Post subject: Re: Can a 1980 Rabbit engine (EJ code) go into 1988 Cabriolet? |
It will fit in place but you’ll end up with an absolute nightmare. Cooling hose routing, vacuum hose issues, accessory brackets, fuel injection, exhaust & intake manifolds & ignition system will all have to be swapped & then you have a smaller displacement engine that won’t play well with the engine management system. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
vwjetboat Samba Member
Posted: Fri Jun 08, 2018 4:33 am Post subject: Re: Can a 1980 Rabbit engine (EJ code) go into 1988 Cabriolet? |
real easy.. with a 2bbl carb setup |
Posted: Fri Jun 08, 2018 6:28 am Post subject: Re: Can a 1980 Rabbit engine (EJ code) go into 1988 Cabriolet? |
vwjetboat wrote: |
That'll make a great planter for your front yard. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Fri Jun 08, 2018 7:52 am Post subject: Re: Can a 1980 Rabbit engine (EJ code) go into 1988 Cabriolet? |
I would not want to put the effort into it. You can buy a correct used engine for a couple hundred bucks.
To answer your question, anything can be done with the right amount of time and money. |
