VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Thu Jun 07, 2018 11:19 pm Post subject: Electrical - Aux battery and Fuse 3 - No lights and no cig |
Just installed an auxiliary battery. Yandina combiner, Blue Seas fuse box, the whole 9 yards. Works fine, EXCEPT one thing... I can't have the radio/lights/cig lighter run on the aux battery.
Vehicle: 1990 Westfalia full camper. had the relay under the driver's seat.
What I did: install the aux battery. I used the existing red wire that runs from the driver's seat battery box to the fuse box, removed it from panel P (permanent +12V) and plugged it in lower socket of fuse 3, so I could have radio/lights/cig run on the aux battery.
What happened: The lights and cig lighter stopped working, the radio still worked.
I removed the spade. Turns out:
1/ There is +12V at the lower spade of fuse 3 socket, contact on or off;
2/ The radio works no matter what, i.e. it is not on fuse 3.
Questions:
1/ How is my radio powered? Are we looking at a possible case of PO's bamboozle?
2/ If my radio is not on fuse 3, why do I have +12V at the lower socket of fuse 3, and why won't the lights work?
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Fri Jun 08, 2018 1:08 am Post subject: Re: Electrical - Aux battery and Fuse 3 - No lights and no cig |
There are 2 versions of the 86-91 fuse panel. The 2 pins for fuse #3 are reversed in the later version.
With nothing in the 2 pins of fuse slot #3, measure the volts on each pin compared to ground. 1 pin should have constant +12 from the main battery.
DON'T use that pin. Plug the aux battery wire spade into the OTHER pin. That should move what was using fuse #3 to now use the aux battery power. Make sure the wire from the aux battery has a fuse near the aux battery end.
As for why the radio works with nothing in fuse slot #3, sounds like a previous modification.
Mark |
VicVan Samba Member
Posted: Fri Jun 08, 2018 12:51 pm Post subject: Re: Electrical - Aux battery and Fuse 3 - No lights and no cig |
Lux fiat! It works. Thanks Mark.
Regarding the inversion of the fuse for the later models, is it something I could have found out on the Bentley?
I put a 15 A fuse.
As for the radio, I'll have to do some exploration... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
