Omario Samba Member
Posted: Fri Jun 08, 2018 1:34 am Post subject: Newbie - Recommendation for mechanic in the bay area |
Hello All,
I purchased almost fully restored 59 bug a month ago. After purchasing the car, I took it to THE most famous shop in the San Francisco bay area to do a trany rebuilt and to address an engine oil leak. Was told the cause of the leak is the main seal. Got my car back after the trany rebuild and main seal replacement, and notice oil drops in the garage. Took it back to the mechanic and they informed me that the axle boot clamp need to be repositioned and the oil leak is resolved. Drove home, notice that the oil drops are more. Decided to learn more about the aircooled engines on you tube. Opened the engine door and noticed that the leak is coming from the left of the engine S/N is engraved. It is exactly dead center (if you to split the engine into 2 halfs). Not sure what the source is. I do not believe the mechanic even looked at the engine compartment, they just looked at the car from underneath. I checked the reviews on yelp, and it seems a similar story. To make a long story short, need a recommendation for another mechanics. Help questions:
1- Recommendation for Mechanic shop in the SanFrancisco bay area.
2- How much should it cost to take the engine out and replace all seals. Car runs amazing with no issues at all. No smoke or nothing. Besides the leaks, the car is a 10/10. Like a brand new car.
I forgot to mention that the current shop kept my car for 3 weeks to do a trany rebuild and when I got back, it did not want to shift out for reverse. Had to return the car back and it was kept for another 2 weeks. When I got it back, this is when I noticed the oil leak.
Specs: 59 bug with a single port 1600 engine
74 Thing Samba Member
Posted: Fri Jun 08, 2018 9:42 am Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
What shop did you take it to in the Bay Area?
The engine has the wrong distributor-it should have a vacuum distributor for the single port. It also looks like you have a gap in the engine tin just to the rear of the dip stick.
Where exactly is the leak coming from? From your description you indicate the left side, but from the photo you show the rear of the engine and the leak appears on the right side under the generator stand and under the crank pulley. Is that where your leak is coming from? (Left and right are described as if you were sitting in the drivers seat of the vehicle). |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Fri Jun 08, 2018 9:54 am Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
possibly just too much oil pressure. How big of a leak are we talking about, a few drops over night?
I've never had a vw that didn't leak a little. It's an old car. It can be done, but it's going to be very expensive for you to pay someone to tear down your engine, when you've stated it runs fine.
You're going to need to learn to work on cars yourself. I honestly never hear anything good about any shops in the bay, but where exactly are you? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Omario Samba Member
Posted: Fri Jun 08, 2018 10:13 am Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
I used Lavere's restoration. I am in east bay. Attached is the direction of the leak. I wish I had the skill set to work on it my self.
I am Ok if it leaks a bit, but the oil is now getting sprayed in the inside of the hood and on other components. |
Omario Samba Member
Posted: Fri Jun 08, 2018 10:14 am Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Posted: Fri Jun 08, 2018 12:26 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
If it is "spraying" and it appears to be on the case behind the crank pulley then most likely the leak is coming from that area.
There is no seal on the crank pulley area (at least as stock). Instead there are spiral grooves on the pulley to keep the oil inside.
Is your engine overfilled with oil? Is the breather hose clear? It looks like you have the downdraft tube on the oil filler so that is good. Are you sure none of the oil is coming from the oil filler or cap area?
The only alternative is to get a bolt in or machine in sand seal pulley. Basically a seal gets installed on that end of the case and the pulley that accompanies it does not have any grooves but is a smooth cylinder.
You can try Buggy House in Hayward. Tell them that the engine is leaking oil behind the crank pulley and spraying your decklid. |
Omario Samba Member
Posted: Fri Jun 08, 2018 1:48 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Thanks 74 thing for the reply. I do not believe that the leak is coming from the pully area. my guess, oil is dripping on pully thus spraying everywhere.
I added more pictures. If you think of the engine is too halves (looking at it from the back or the car with one half on the left and the other half on the right), the leak is coming from where the 2 halves meet. At least from where I can see. Need to remove the tin to see it extends all the way towards the fly wheel area.
Red line is the split of the 2 halves. Yellow/green is the oil drop path (I believe)
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Fri Jun 08, 2018 2:09 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
First, clean everything off with some Gunk, or similar degreaser and let it dry thoroughly. Then start the engine and let it run until you can see exactly where the oil's coming from. Once that's been established, it'll be easier to recommend how to proceed. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Fri Jun 08, 2018 2:48 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Easiest way to determine where it is coming from is get some brake cleaner some towels and some white foot powder spray. clean the areas good and then spray it with the powder and start it up and you should see where it is coming from hopefully. Maybe the generator stand too. |
Spezialist Banned
Posted: Fri Jun 08, 2018 4:02 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Oil cooler and or it’s seals _________________
Omario Samba Member
Posted: Fri Jun 08, 2018 4:14 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Thanks for the excellent advice. I will clean up everything than repost after findings. |
Erik G Samba Member
Posted: Fri Jun 08, 2018 4:31 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
oil filler looks loose. the green lines on the right. get a 13 mm wrench and tighten those 4.
the fuel pump too (left green lines) but not too tight
and clean and start and report back. Post a pic of the level on the dipstick as well, before you start it up _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Erik G Samba Member
Posted: Fri Jun 08, 2018 4:48 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
from the reviews here
don't go to Tassi
NO to buslab
no to Griffin
If you can deal with Belmont, Jansen enterprises has a good rep. Ask the locals about buggy house in hayward.
I know a great guy all the way in Sacramento _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Fri Jun 08, 2018 5:11 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Erik G wrote: |
If you can deal with Belmont, Jansen enterprises has a good rep. |
I've never needed Ken's (Jansen) help, but I have friends who've used him and they have all good words about him. I checked yelp and he rates highly.
OP, the East Bay is big, are you near the southern end, like Fremont or thereabouts? |
Rome Samba Member
Joined: June 02, 2004 Posts: 9640 Location: Pearl River, NY
Posted: Fri Jun 08, 2018 5:50 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Quote: |
oil filler looks loose. the green lines on the right. get a 13 mm wrench and tighten those 4. |
Good spotting; I agree. I'd guess that the nuts can be tightened maybe 2 turns, seeing how the bottom of the nuts are not in full contact with that ledge*. Note to the OP- those nuts have "nylon" inserts which act as locknuts. You'll feel a uniform drag as you snug each one down until it can't turn much anymore. That's a characteristic of such inserts. The torque spec for the nuts is 14 ft. lbs. If you don't have a torque wrench, tighten each nut down until the drag increases, signaling that you're all the way down onto the ledge. Then give the wrench a mild sideways rap with your palm to give it the final set.
*BTW to the OP- the "oil filler" is actually generally referred to as the generator stand. The actual oil filler is attached to it on the right side, consisting of the black metal "pod" and the aluminum oil filler cap. But your stand is designed for an alternator, though it is working fine for the generator that is on your engine. Too bad the crankshaft pulley has its paint already scraped off.
And you are correct, the engine "case" does consist of two halves which meet in the middle.
Phooey to the repair shop that rebuilt the transmission but did not take it on a test drive to immediately notice that you can't shift out of reverse! |
Spezialist Banned
Posted: Fri Jun 08, 2018 7:34 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
I know a guy who’s mobile but his clientele is very exclusive. _________________
Omario Samba Member
Posted: Mon Jun 11, 2018 7:40 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
I really appreciate everyone’s help. I cleaned the engine compartment and bottom of the engine thoroughly and ran it around the block and found where the leak is coming from. It is from the fuel pump stand (left green lines). I did try to tighten them but still leak. However, the degreaser I used ate up the gasket/seal for the oil filler/generator stand. I used one from Auto Zone. No leaks form there but the gasket/seal got eaten up.
Also, found out the root cause for all this. These guys when they did an oil change, they overfilled the engine with too much oil. See dipstick. I was able to suck oil out of the dip stick hole to make acceptable. But I believe the damage is done. Need to replace the seals for fuel pump stand.
Finally, I couldn’t tight the right/back corner screw for the generator stand due to accessibility. Any advice? (Yes I know it is not the source of the leak, but I tightened 3 and only missing one)
Rome Samba Member
Posted: Mon Jun 11, 2018 9:05 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
For that right-front generator stand nut, you have at least 2 wrench choices in that cramped area. 1 is a sideways-curved 13mm box-end wrench which is sold by VW vendors to access the front mounting nut for the carburetor. Also known as a "half-moon" wrench. If you have time to wait for a delivery, that is a useful tool. 2. If you don't have time, you can try a stubby (short handle) 13mm open-end wrench. http://www.google.com/shopping/product/10558449353...DDMQ8wIIMQ
This one from Sears would also work, whereby the ratcheting box-end may not have enough clearance to the stand's vertical surface to get it fully down onto the nut. http://www.sears.com/gearwrench-13mm-full-polish-s...NwodPKoB1A
Good going with diagnosing the leak! When you remove the fuel pump and the Bakelite stand, first pull out the metal pushrod in the center of the stand. CAREFULLY pull the stand up off the two studs. It is common for the stand's base to be slightly stuck inside the engine. First try to pull the entire stand straight up with your fingers. Don't try to grip it with a tool because the Bakelite material is brittle. Hopefully you'll be able to pull the stand fully out easily. Look inside the bottom of the fuel pump body to make certain it is filled with grease. This is needed for the lubrication of the "lever" which pumps up and down by the pushrod when the engine is running. The grease stays in place by the upper stand gasket. Once you have the new gaskets and the fuel pump (and pushrod; thin pointy end goes down into the engine) in place, tighten the two M8 nuts evenly and gently. |
Omario Samba Member
Posted: Mon Jun 11, 2018 10:59 pm Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Thanks Rome for the advice.
I was informed that the engines require a service every 3000 miles. What does the service include?
Oil change
Gaskets replacement (which ones?) Valve cover, etc...
Valve adjustment?
I live in Pleasanton and found a local guy that seems to be very knowledgeable. His name is Tony and he owns beetle power. I am thinking of letting him do the service but I want to know what is typically done. |
Posted: Tue Jun 12, 2018 7:07 am Post subject: Re: Newbie - Recommendation for mechanic in the bay area |
Tony at Beetle Power is a good guy. Tell him that you need the fuel pump resealed and to tighten the gen stand and to check for any other oil leaks.
You can always go to Harbor Freight and get cheap stubby wrenches or s shaped wrenches and cut down a wrench for your needs.
Tell him your oil was overfilled as well.
I would ask him about the correct vacuum distributor for your engine/carb combination too-it will improve driving a lot most likely.
Every 3k-change oil (including cleaning strainer), change oil in oil/air bath cleaner, valve adjustment, check dwell on distributor and timing, change fuel filter if disposable one, adjust carb when warmed up to operating temp, adjust brakes. Thats what I can think out of the top of my head. You should learn to do these yourself even if you decide to use a mechanic so for the just in case times. |
