hinges
mtsolari
mtsolari is offline
PostPosted: Fri Jun 08, 2018 8:30 am    Post subject: hinges Reply with quote
does any know what the spring loaded hinges under a thing rear seat are for ?
Ron Domeck
Ron Domeck is offline
PostPosted: Fri Jun 08, 2018 2:11 pm    Post subject: Re: hinges Reply with quote
Holds the seat backs upright. When you fold the seats in cargo mode they are not used.
mtsolari
mtsolari is offline
PostPosted: Fri Jun 08, 2018 2:47 pm    Post subject: Re: hinges Reply with quote
I put the seat up and down and see no use for the springs or the 2 small hooks on the sides of the 4 hinges..
Ron Domeck
PostPosted: Fri Jun 08, 2018 3:18 pm    Post subject: Re: hinges Reply with quote
The little hooks are were the springs hook to have tension. Your seat will rattle without this setup. This is what the seat back should be latching into. If you are only latched in the rear the seat will swivel and the back will lay to the back.
