62kellison Samba Member
Posted: Sun Jun 10, 2018 5:48 am Post subject: replacement speedometer bulbs?/how to remove front glass??... |
hey guys does anyone sell replacement speedometer bulbs?,and the little canister with the metal prong that holds the bulb?.and how do u remove the glass off of your speedo to clean the inside?.is there a link on this anywhere?.also are the prongs suppose to be wiggly on the little canisters that hold the bulbs?...any info be great.trying to clean and refurbish mine.its around a 70,s I think.it has gas gauge built into the speedo. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20360 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jun 10, 2018 6:06 am Post subject: Re: replacement speedometer bulbs?/how to remove front glass??... |
Here is a couple of places for your bulbs and holders...
http://www2.cip1.com/searchresults.asp?cat=1730
http://www.westcoastmetric.com/c-1169512-vw-bug-1946-1979-electrical-light-bulbs.html
Only way into speedo I know of it remove front chrome bezel, have not done that so I can't help you..
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5305 Location: Central Florida
Posted: Sun Jun 10, 2018 6:23 am Post subject: Re: replacement speedometer bulbs?/how to remove front glass??... |
You can remove the glass by carefully prying up the lip on the backside of the speedo. Doesn’t need to be much, just enough to get the glass out. Then when done carefully bend it back. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Ken Samba Member
Joined: November 14, 2005 Posts: 129 Location: Spokane, WA.
Posted: Sun Jun 10, 2018 12:08 pm Post subject: Re: replacement speedometer bulbs?/how to remove front glass??... |
Several people in the classifieds sells both the plastic and metal housings. I bought 10 for 8 bucks shipped a few months ago. Actually got 15, and enough good bulbs included to outfit my speedo. And like said above, carefully lift chrome ring from front, you'll see two notches in the trim where the mounting tabs are. Use a small flat tip and slowly pry it off. To reinstall, hook the trim in place at the tab notch where you removed it and "spiral" it back on, at the last 1/2" or so remaining, slip the flat tip under it and work it into place, it will -pop- back on. Just did it last weekend to mine to clean it and replace the indicator plastics. |
Posted: Mon Jun 11, 2018 4:26 am Post subject: Re: replacement speedometer bulbs?/how to remove front glass??... |
once again Thanks guys for all the help!!! |
markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Wed Jun 13, 2018 6:51 am Post subject: Re: replacement speedometer bulbs?/how to remove front glass??... |
I just ordered some yesterday from Wolfburg West; both bulbs and holders. |
Posted: Wed Jun 13, 2018 8:28 am Post subject: Re: replacement speedometer bulbs?/how to remove front glass??... |
worked great guys.i had a little 4 piece seal remover hook set from walmart.real cheap set.the angled one slipped behind the metal ring.i slid it around the speedo.it opend up the ring just enough.and i didnt leave any pry up marks, by sliding it around the inside edge of the ring.looks really nice!.thanks.bulbs and canisters r ordered. |
