Danny Taylor Samba Member
Joined: January 03, 2018 Posts: 1 Location: Pass Christian, MS
Posted: Mon Jun 11, 2018 2:37 pm Post subject: '93 Eurovan MV with 285,000 mi., that flooded in Katrina |
My above referenced Eurovan was running great when Hurricane Katrina, in '05, flooded it out. It hasn't run or moved since. The water level reached to top of the CD player under the passenger seat, but did not get the seats wet. I have been using it for storage since, but now my neighborhood is finally coming back from the storm and real estate values don't allow a derelict camper van in one's side yard. Even if it is a VW bus. So what do I do with it?
I don't want to give it to the junk yard if there is a Eurovan enthusiast who might want it. It has some rust in all the wrong places and I have pictures I can post if anyone is really interested, and I can figure out how to do that. It's located in Pass Christian, MS. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Jun 12, 2018 4:20 am Post subject: Re: '93 Eurovan MV with 285,000 mi., that flooded in Katrina |
If you fresh water rinsed it shortly after flood it might be worth recovering, if not, I’m not even sure it’s got parts value above scrap. _________________ .ssS! |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Tue Jun 12, 2018 9:23 am Post subject: Re: '93 Eurovan MV with 285,000 mi., that flooded in Katrina |
Joshwa wrote: |
If you do scrap it, at least pull the ECU and gauge cluster. Those can get you back a couple hundred dollars each on ebay. They would have been above the water level the van was at, and are easy to remove. It would be throwing away money to scrap those two pieces. |
I disagree, that cluster has been subjected to lots of humidity & is probably worthless, the ECU may have been under water due to the nose heavy nature of a EV if it was floating before it flooded enough to level off. I think it's time to cut your losses. Sell it as scrap or put an ad up & see what you can part off of it.
If you part it out, I would be interested in the front bumper & some nose pieces. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Joshwa Samba Member
Posted: Tue Jun 12, 2018 10:05 am Post subject: Re: '93 Eurovan MV with 285,000 mi., that flooded in Katrina |
Joshwa wrote: |
The ECU is a sealed unit. If the van is able to power up and you see the needles move, then take the cluster. “Probably” and “maybe” do not equal bad. |
It is a sealed unit, but not against submersion. Definitely check them out & see what you can salvage. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
