Measurements for top restorations
dan macmillan
dan macmillan is offline
PostPosted: Mon Jun 11, 2018 3:13 pm    Post subject: Measurements for top restorations Reply with quote
I am planning on ordering a new top with frame from the Thing shop.
I want to make sure everything is lined up and correct before dropping $2300 Canadian. Can someone with a properly fitting top post the following measures
Windshield angle in relation to top of front door.
Top of windshield frame (not including top seal) to top of front door 90 deg to door.
Windshield frame outer dimensions
Distance from rear upper body lip to hinge point of all top cross bars
Distance from top of rear door to bottom of horizontal top bar.
Distance from top corners of windshield frame to top rear corners of body lip.
Pictures would be awesome.
Thanks
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
77kafer
77kafer is offline
PostPosted: Mon Jun 11, 2018 7:16 pm    Post subject: Re: Measurements for top restorations Reply with quote
Dan. Have you thought about sending a message to Ron Domeck on here? He and his brother are the resident 181 restorers.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
dan macmillan
PostPosted: Mon Jun 11, 2018 8:24 pm    Post subject: Re: Measurements for top restorations Reply with quote
Thanks for the info.
Current projects:
Ron Domeck
Ron Domeck is offline
PostPosted: Thu Jun 14, 2018 3:16 pm    Post subject: Re: Measurements for top restorations Reply with quote
Dan, windshield frame 18 5/8 tall, top of frame 52 7/8, bottom of frame 56 7/8, windshield angle 60 degrees. Top of windshield to door at the top alignment hole the top of pinch weld on door 16 1/4, Pivet point center to back pinch weld 28 in. , Top of windshield at alignment pin hole to rear body pinch weld at corner 81 1/4 in. This was on a original paint never damaged car. Hope this helps. Looking at your picture of your car it may best to replace the windshield frame. Let me know how this works.
77kafer
77kafer is offline
PostPosted: Thu Jun 14, 2018 7:06 pm    Post subject: Re: Measurements for top restorations Reply with quote
Dan, there you go !!
