Quintanamobay Samba Member
Posted: Mon Jun 11, 2018 4:09 pm Post subject: Steering wheel play inside of steering box 78 bus |
Hey everyone!
I have about 3 - 4 inches of play in the steering of my 78 bus. I hopped under the bus and noticed that the play is starting inside of the steering box, not after it. Today I purchased all of the tools for a "Phase 2" tool kit as described in the John Muir - How to Keep Your Volkswagen Alive.
After searching the forum I have found little tid-bits of how to check the different components of the steering system, but no definitive procedures. I have ordered both the Haynes and Bentley manuals, but they will not be here for a few days!
Could anyone point me in the direction of a good diagnostic procedure before I jack up the bus up?
A video of the play: https://www.youtube.com/watch?v=F3yq1lJEKs8[/url] |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Mon Jun 11, 2018 5:37 pm Post subject: Re: Steering wheel play inside of steering box 78 bus |
There's an adjustment screw on the side of the steering box. Loosen the lock nut, 19mm I think, and turn the screw in until the play is gone. The drag link should be disconnected from the steering box drop arm so you don't over tighten the adjustment screw. The steering wheel should turn freely, lock to lock, with absolutely no binding. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Tcash Samba Member
Posted: Mon Jun 11, 2018 6:33 pm Post subject: Re: Steering wheel play inside of steering box 78 bus |
Have someone turn the steering wheel while you inspect the drag link ends, center link and tie rod ends.
Steering Play |
SGKent Samba Member
Posted: Mon Jun 11, 2018 7:16 pm Post subject: Re: Steering wheel play inside of steering box 78 bus |
maybe this will help. Be sure you keep it full of gear lube.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Jun 11, 2018 11:31 pm Post subject: Re: Steering wheel play inside of steering box 78 bus |
SGKent wrote: |
This worked beautifully. Thank you so much kent. Is the steering wheel supposed to come back to center on its own after making a turn? I don’t know if it was doing it before, but it’s definitely not now haha. |
SGKent Samba Member
Posted: Tue Jun 12, 2018 6:49 am Post subject: Re: Steering wheel play inside of steering box 78 bus |
maybe you are a tiny bit too tight. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
