john0 Samba Member
Joined: September 22, 2011 Posts: 13 Location: Seattle
Posted: Tue Jun 12, 2018 5:37 pm Post subject: Carburetor sizing |
I'm currently running dual Weber 40 carbs with a crossbar linkage in my 1969 Square. I have no problem with their performance in fact it's awesome. I just reaaaally wish I could get at the rest of my engine, particularly plug wires. I have scars.
So I'm thinking about replacing the system with smaller carbs. Would that make any difference and if so, any suggestions?
Thanks ahead of time.
-john |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Tue Jun 12, 2018 9:02 pm Post subject: Re: Carburetor sizing |
Unbolt the intake manifolds & carburetors together & take them off when you are changing spark plugs etc. Move your coil from the left over to the right.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Danwvw Samba Member
Posted: Tue Jun 12, 2018 9:11 pm Post subject: Re: Carburetor sizing |
Has anyone tried NDIX 32 Zeniths on a Type 3? Much smaller and capable of plenty of flow on a 1600cc. or similar size engine. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Slow 1200 Samba Member
Posted: Wed Jun 13, 2018 7:19 am Post subject: Re: Carburetor sizing |
I always wondered about NDIX on a type 3, since they use almost the same bolt pattern as the DCNF Webers, my impression is that they are too tall to really fit under the engine cover |
john0 Samba Member
Posted: Wed Jun 13, 2018 11:27 am Post subject: Re: Carburetor sizing |
Thanks for the suggestions!
-j |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
Danwvw Samba Member
Posted: Wed Jun 13, 2018 2:26 pm Post subject: Re: Carburetor sizing |
I just measured the NDIX and a Dellorto 36:
Zenith NDIX 32 is 5" Base to top Rim.
Dellorto 36 is 5 1/2" Base to top of Main Jet and short stack however the Dell is only 4" from base to top.
Dell Main Jet and stacks go into the Air Cleaner space.
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
