hazaa Samba Member
Posted: Thu Jun 14, 2018 1:07 pm Post subject: help regaridng t2 sliding door sill |
hi guys, iam now restoring T2 and have some problems with sliding door side sill, there wa so much rust so i needed to cut all out and didnt have sample to understood how it all should fit back
inside sill should stand like this:
or like this
and in rear should i bend this ( red ) part so i can put inside sill on it or
i need to put upper tube longer so sill dosnt touch that part?
middle sill i have with sliding door trail
and there is question if this sill should stand like this:
or it should be little more outside
how i understood these should touch
and the pillar should touch the middle silll but there is big gap do i need to bend pilar to it ( to push sill more out?)
and maybe some one can give what is the length between right and left sill? (so how long should be parts on witch lays buss floor) |
hazaa Samba Member
Posted: Fri Jun 15, 2018 12:41 am Post subject: Re: help regaridng t2 sliding door sill |
any idea? |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Fri Jun 15, 2018 5:26 am Post subject: Re: help regaridng t2 sliding door sill |
The middle sill goes tight against the pillar,it does not attach to the inner sill at the top,the floor is what bridges the gap between the inner and middle sill.
go check the build treads and gallery for pic and info. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Tcash Samba Member
hazaa Samba Member
Posted: Fri Jun 15, 2018 1:56 pm Post subject: Re: help regaridng t2 sliding door sill |
lil-jinx wrote: |
go check the build treads and gallery for pic and info. |
yes i know that middle sill dosnt touch the inner sill but pilar touches the middle sill only on bothom or in full? becuase how you can see it touches only on bottom on top is big gap, i need to put some metal in that gab or the floor will cover that gap??
hazaa Samba Member
Posted: Sun Jun 17, 2018 9:59 am Post subject: Re: help regaridng t2 sliding door sill |
so i put in inside sill, but that i tryed to manage to put in middle sill with sliding rail, i spend 8h and still could manage to fit it, if adjust one place other moves and its not straight.... aa got angry
the sill with sliding rail it should be straight parallel to ground or it should be in small angle, because lower hings rollers are not straight they are also in angle.
maybe some one have some guidance how to do the best or how much cm or what angle should be where... |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2536 Location: Plattsburgh, New York
Posted: Mon Jun 18, 2018 6:11 am Post subject: Re: help regaridng t2 sliding door sill |
I did this repair about 20 years ago on my bus and had a look at it after reading your thread. My door track seems to be at a slight angle with the outer edge slightly higher compare with the rest of the cargo floor. I tend to doubt that it is supposed to be that way, but my sliding door works and fits well.
When I replaced mine, I used clecos and small machine nuts and bolts to hold it all together and reinstalled the door to test for fit and moving smoothly. I remember getting really frustrated spending hours not being able to get it to quite fit so I called it a day, cleaned and sorted my tools, picked up the shop and went home. The next morning I was able to sort it out in about a half hour. I also remember doing a lot of measuring making sure the cargo remained square.
I would highly suggest you buy the Haynes restoration manual as well as reading other build threads. It's also a good idea to not cut away too much metal at once from the bottom of the bus, even if it something you plan to replace. It's good to have original reference points as to where things go. Best of luck. |
