kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Thu Jun 14, 2018 1:19 pm Post subject: Upgrading Throttle Cable |
This topic comes about due to my throttle cable busting last night in the beginning of my 30 mile commute home through traffic. I was somehow able to channel my inner MacGyver and use a ring terminal clamped to the broken end of the cable by the pedal, which was then zip tied to the roller pedal. I babied that thing home for 30 miles hoping and praying it would stay clamped on the cable. Thankfully it did.
Bottom line is, I need something a little more robust. That throttle cable was 2 years and maybe 6000 miles old. Shouldn't be busting. I kinda wanna just get a piece of appropriately sized cable and make my own set up, but I was wondering if anyone had ideas about how to attach/connect it to the roller pedal. I have a barrel in back holding it to the throttle body, but I need some ideas for the front/pedal. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
AlmostHeavenWV_VW Samba Member
Posted: Thu Jun 14, 2018 1:48 pm Post subject: Re: Upgrading Throttle Cable |
I applaud your skills of getting home!
Although throttle cables don't normally fail so quickly. I would be suspicious that something is bent or rubbing/wearing the cable at an abnormal rate. A heavier duty cable may give you more time between breakages, but I would thoroughly investigate any possible causes to the throttle cable breaking before I would simply go to a heavier gauge cable. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Jun 14, 2018 2:31 pm Post subject: Re: Upgrading Throttle Cable |
You can try something like this
https://www.ebay.com/itm/THROTTLE-CABLE-Universal-...SwZW5aAI6i
and use a self locking nut on a bolt like this but make sure your roller is not bent like this one
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Jun 14, 2018 2:35 pm Post subject: Re: Upgrading Throttle Cable |
You didn’t happen to install the fairly new “S”-hook end of the cable from the left side of the pedal pivot arm? If so, installing from the left can cause the end to wear rapidly. The S must be installed from the right side of the pivot arm. And grease it well, including the hole in the pivot arm.
I use needle nose pliers to install, since the area there is kind of small next to the tunnel.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
cbeck Samba Member
Posted: Thu Jun 14, 2018 2:38 pm Post subject: Re: Upgrading Throttle Cable |
Try cardinal door down the street from the vet. Might have a assortment of cable ends you might be able to adapt to your pedal. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Frodge Samba Member
Posted: Thu Jun 14, 2018 2:56 pm Post subject: Re: Upgrading Throttle Cable |
Tim Donahoe wrote: |
Tim |
Can you see this without taking the pedal assembly out? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Jun 14, 2018 3:41 pm Post subject: Re: Upgrading Throttle Cable |
A stock accelerator cable goes in this way !!!!
I've not tried the newfangled type of accelerator cable. My 1970 VW has over 260K miles on the original cable; my 1971 Super is on its third (150K).
60ragtop wrote: |
make sure your roller is not bent |
Very true _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jun 14, 2018 7:50 pm Post subject: Re: Upgrading Throttle Cable |
One of the reasons it has accelerated wear is because I have a big ass spring on the throttle body cause the one it came with is a dinky lil thing. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-18 GTI SE
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Chris333 Samba Member
Posted: Thu Jun 14, 2018 11:39 pm Post subject: Re: Upgrading Throttle Cable |
I bought the heavy duty one, it works good. My car came without one and I put a stock cable in and it felt like the cable would come un-hooked from the pedal if I looked at it wrong.
The heavy duty one I got from J-bugs was just an Empi part and since the clevis is so much longer than stock you have to cut your tube back a little.
Here is a video showing the tube cutting:
https://www.youtube.com/watch?v=OcVp5BdV1zw
Mine is just like the one shown in the vid.
I also bent the clevis to match the angle of the pedal so there was no angle on the cable.
https://www.jbugs.com/product/4862-7.html
Somehow the 16' cable is $1 less than the 9' cable. I wicked a bunch of solder onto mine at the carb and then trimmed it off. |
cbeck Samba Member
Posted: Fri Jun 15, 2018 4:40 am Post subject: Re: Upgrading Throttle Cable |
To take max's garage door cable one step further, there are thimble's available for the loop. That is a small metal piece that is fit inside the loop before it is crimped that acts as your wear surface. While ln that dept look for a chain master link (45 or65?) to make the connection to your pedal. Cardinal door in your zip code should have that and more, should be able find something that will get you going. _________________ My cut in half and rebuild thread
Posted: Fri Jun 15, 2018 6:44 am Post subject: Re: Upgrading Throttle Cable |
Some really good ideas here gents. I'll prolly do a spin off of Max's idea there, and then incorporate the thimble as cbeckmentioned to prevent excessive wear.
I do like the heavy duty cable that was linked as well too. We have one of those on our buggy that has been there for 15 years.
Thanks for the ideas all. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-18 GTI SE
Cusser Samba Member
Ricksurfin Samba Member
Joined: September 02, 2017 Posts: 295 Location: Huntington Beach, CA
Posted: Fri Jun 15, 2018 8:42 am Post subject: Re: Upgrading Throttle Cable |
With the wire, do you just run it through the barrel nut on the carburetor and clamp directly on the wire, or do you put some kind of end on the wire? |
Cusser Samba Member
Posted: Fri Jun 15, 2018 11:09 am Post subject: Re: Upgrading Throttle Cable |
Ricksurfin wrote: |
If I did this, I think I'd try to solder the strands at the rear just after cutting to length to prevent them from fraying. I'd try this so upon subsequent disconnects of the accelerator cable that I'd be able to readily thread it through the barrel nut. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mark tucker Samba Member
Posted: Fri Jun 15, 2018 11:45 am Post subject: Re: Upgrading Throttle Cable |
wow thats effed up....get the cable to pull inline with the tube. nd for maxs fix ....use a longer bolt so it is pulling out of the center of the cable tube.I would also use 2 spacers,one that rotates on/over the other one.
As for the op's isssue.. I put a new cable on last year some tyme. I use the 76 fuel injection cable (pioneer brand). it has a graphite impregnated graphite sheeth on it. oh so smooth. and cheeper than the non fuel injected cable Ill see if I can find the pioneer #............hmm......... CA 8571 . I got it from orileys. |
Posted: Fri Jun 15, 2018 12:50 pm Post subject: Re: Upgrading Throttle Cable |
That photo is how mine would have been, but I bent the end to match the pedal angle. |
Posted: Fri Jun 15, 2018 2:33 pm Post subject: Re: Upgrading Throttle Cable |
Cusser wrote: |
Likely Max added some grease to his loop and area before putting into actual operation. |
I actually did not. My thought was that grease would just attract dirt down there. The car was a 12 month daily driver and I was constantly tracking in dirt and mud and snow. It lasted something like five years and was still going strong when i sold the car.
On the other end of the cable I just folded the it over and tightened the barrel nut against it.
I used to carry 25' of that stuff around in a ziplock with the heavy pliers and a few ferrules. Came in handy a few times ... to fix other peoples cars.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Fri Jun 15, 2018 8:47 pm Post subject: Re: Upgrading Throttle Cable |
"One of the reasons it has accelerated wear is because I have a big ass spring on the throttle body cause the one it came with is a dinky lil thing"
Long term I would be concerned by putting a stronger return spring than standard on the carburettor. This puts additional load on the throttle butterfly shaft which cannoot be good from a wear point of view. |
