guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Thu Jun 14, 2018 4:26 pm Post subject: lubing wipers and air control levers |
I kinda have my dash out and think I should lube my wipers and air control levers with while I have OK access
I was thinking silicon spray for levers
grease for wipers _________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
Tcash Samba Member
SGKent Samba Member
Posted: Thu Jun 14, 2018 5:09 pm Post subject: Re: lubing wipers and air control levers |
the best way to lube the heaters is a motorcycle cable lube kit. You can spray white grease on the lever fulcrums if you want. My new cables went from medium pull to really easy when I used a motor cycle cable lube kit like someone here suggested. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jun 14, 2018 5:22 pm Post subject: Re: lubing wipers and air control levers |
Remove the wiper assembly and dismantle the shafts from the pivots for a cleaning and lube, no amount of external spraying of anything will free them up, if you don't they sieze and destroy the wiper motor. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Thu Jun 14, 2018 6:45 pm Post subject: Re: lubing wipers and air control levers |
Power injection cable luber.
https://www.walmart.com/ip/Cable-Luber-Power-Injec...mp;veh=sem
You can tape the straw to the cable, to force lube down the cable housing. Old school.
For the bel cranks that the wiper arms attach to. Use a boat wheel bearing grease. This grease is water proof and will prevent rusting not if but when water gets in there.
The rest of the linkage gets white lithium grease.
Good luck
Tcash |
