skunther Samba Member
Joined: August 24, 2017 Posts: 19 Location: Washington
Posted: Thu Jun 14, 2018 5:52 pm Post subject: Temperature Gauge Faulty? |
I got a temperature gauge installed in the pressure relief valve on my 1977 Type 2 bus (2.0 Type 4 engine). The temperature gauge regularly reads ~240 degrees. My mechanic, who did a complete rebuild of the engine, said that at times those gauges are faulty. Well I don't see the point in going through the trouble of installing one if you can't trust it.
Is there any way to verify the accuracy of the gauge? He had suggested buying a laser thermometer gun and using that. I've never used one, but want to be sure I'm not overheating my engine after spending so much on rebuilding it.
Any suggestions?
Much thanks in advance. _________________ 1977 Campervan Pop Top, "Pepe" |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jun 14, 2018 5:57 pm Post subject: Re: Temperature Gauge Faulty? |
Spend the $20 on the laser gun, you'll find yourself using it for everything and wonder how you ever lived without one.
A meat or fryer thermometer down the dipstick tube also works if you can find one that's long and skinny enough. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Fri Jun 15, 2018 4:38 am Post subject: Re: Temperature Gauge Faulty? |
+1 on laser gun.
If you do find a long enough temperature probe to go into the dipstick tube and compare your readings as busdaddy says, that'd be the easiest thing. I'd be weary about sticking anything that's not designed for it into the sump for fear of it accidentally staying there, though.
Another alternative: if you want to test the oil temp sender and gauge, I'd recommend to do it directly (with the laser gun pointed at the engine block, you're measuring the block temperature, which the sender is NOT measuring).
Back when I did this, I went for a simple "kitchen test". It does reauire removing the sender:
• I connected a 12V power supply to the gauge (you can use a battery instead)
• I connected the temperature sender to the gauge (oil dipstick sender[*] in my case)
• I used the temperature probe on my automotive multimeter (most cheap ones have one nowadays)
• I brought water to boiling point and poured it into a bottle
• I submerged the sender and the multimeter temp probe in the water
• I took readings of the multimeter and the gauge display as temperature decreased
Notes:
• The readings are in Celsius, but you get the gist (100 °C is water boiling point)
• You can heat oil in a pan to further increase the temperature and test the gauge's full range. I skipped that because a) I was simply testing if the gauge and sender combo was working at all b) it was rather messy. The oil temp is also a bit difficult to control under the fire (I did try )
• The compared measurements (multimeter vs. gauge) were reasonably accurate and to my satisfaction (I wasn't expecting high precision from the gauge)
• More pictures on my gallery.
[*] I'm aware there are better options and locations for measuring oil temperature. That's the object of another discussion. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
calo1956 Samba Member
Joined: April 18, 2011 Posts: 700 Location: long Island new york
Posted: Fri Jun 15, 2018 5:32 am Post subject: Re: Temperature Gauge Faulty? |
skunther , I would say go with the Laser gun. You can measure temps of everything with it. I pointed mine directly at the oil plug sender right after shutting the van down, and was satisfied with the result. But besides that, you can go bunkers with it, and measure cylinder head temps, exhaust temps, basically every area of your motor. If nothing else its fun! Also useful for checking brake caliper temps wheel bearing temps etc. Im happy i purchased one. I bought mine on Amazon, but you can get them in any big box home center _________________ Enjoy the ride....
72 bug
80 westfalia |
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Fri Jun 15, 2018 6:50 am Post subject: Re: Temperature Gauge Faulty? |
Here is my post from when I used a laser thermometer to verify my oil temp sender that is also located in the pressure relief location. I didnt really come to any conclusion other than the gauge and sender were accurate to the senders location. The real question is what is the actual oil temp and why does the relief location read hotter than everywhere else (exhaust right there)?
Got some various temperature measurements tonight with a laser thermometer.
Heads (VDO gauge with VDO thermocouple on #3 cylinder):
Gauge - 275
Laser - 294
This is with the laser pointed down the #3 hole in the tin. The 294 is the max it recorded while I was moving it around over the hole.
Oil Temp (pressure relief location mounted sender):
Gauge - 220
Laser
Pass side bottom of sump towards rear - 185
Driver side bottom of sump towards rear - 187
Rear corner of sump - 170
Inspection plate - 190
Pressure relief casting section - 220
Hand on the dipstick test - barely even warm
So I think I can safely assume my CHT readings on the gauge will always be about -25deg from actual. That would explain my low 325 readings on a highway run at 3800rpm. 350 is just about perfect for me.
With the oil temp, I really still don't know what to believe. I know my sender and gauge are reading dead nuts to where it is located but I don't understand why that part of the block is ~30deg hotter than anywhere else. Maybe it's best to take an average of them all? That would be ~ 191deg when gauge reads 220deg.
Thoughts?
Tcash Samba Member
furgo Samba Member
Posted: Mon Jun 18, 2018 11:34 pm Post subject: Re: Temperature Gauge Faulty? |
furgo wrote: |
If you do find a long enough temperature probe to go into the dipstick tube and compare your readings as busdaddy says, that'd be the easiest thing. I'd be weary about sticking anything that's not designed for it into the sump for fear of it accidentally staying there, though. |
Expanding on this comment, I just came across the post below while looking for something else, and I had to think of this thread. I hope this helps. I should think by now you have enough alternatives to choose from for your measurement
akscooter wrote: |
A diagnostic tool I made out of a harbor freight food thermometer.
Decode your M-Plate |
Posted: Tue Jun 19, 2018 4:57 am Post subject: Re: Temperature Gauge Faulty? |
I believe shooting the bottom of the case seam several inches forward of the rear of the block gives a good reading of the actual oil temps. Run the engine in normal use, say 10+ miles at 60mph and then quickly pull over and shut the engine down. Let the engine sit for a minute or so so the heat from the oil can reach the exterior of the case (yes the cooling fins do work when going down the road cooling the exterior of the case). If you have a carbureted engine you can also shoot the top of the case.
The food thermometer that Furgo shows, attached to the top of the case should give a good results. Covering the probe with some insulating material like RTV silicone might give more accurate results. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Tue Jun 19, 2018 8:13 am Post subject: Re: Temperature Gauge Faulty? |
When we were discussing this last just a few weeks back.....I found several reputable notations in several places with teating....that this area of the case is in fact commonly a higher temp than almost anyplace else.....and I cant remember the exact reason.....but a large part of it is that its a large mass area....and part of it is that this quadrant of the case has the most hot oil flowing through it.....from the pump, the oul cooler, the filter, the relief valve etc.
Also.....while the laser thermometer definitely has uses....and you should have one anyway because they are too cheap not to......benchmarking oil temps in very close proximity to heat radiating surfaces that are radiating heat in multiple directions.....some across the line of site path of the IR sensor........this is not one of the applications where its useful for more than just a trend. The +/- spread is just all over the place.
I can tell you because my work takes me across a wide range of manufacturing from aerospace, to automotive, to electronics of all type, medical devices, appliance manufacturing etc.......in about 90% of plants and mfg processes....IR laser thermometers are literally written OUT of processes as dangerously inaccurate and only useful as quick checks during R&D.
They are not to be trusted because of how the sensor works and how it gets less accurate over a very short distance and anywhere the line of site air can be contaminated by radiant heat crossing the path.
The best sensor....for cheap money....if you really want to do spot checks on oil and case temps....is having a VOM with a temperature channel and a handful of cheap K-type thermocouples you can put on the ends of rods and sticks to reach where you need to go......very similar to what Furgo just posted. Ray |
Posted: Wed Jun 20, 2018 12:30 pm Post subject: Re: Temperature Gauge Faulty? |
Thanks everyone - I purchased a laser thermometer from Amazon, awaiting its arrival. I'd do the dipstick method too - Furgo, I'd like to set up a dipstick thermometer similar to what you set up - can you provide more specific info on your setup? I saw you had some sort rubber gasket to seal the sensor at the dipstick opening.[/quote] _________________ 1977 Campervan Pop Top, "Pepe" |
Posted: Wed Jun 20, 2018 1:22 pm Post subject: Re: Temperature Gauge Faulty? |
skunther wrote: |
Thanks everyone - I purchased a laser thermometer from Amazon, awaiting its arrival. I'd do the dipstick method too - Furgo, I'd like to set up a dipstick thermometer similar to what you set up - can you provide more specific info on your setup? I saw you had some sort rubber gasket to seal the sensor at the dipstick opening. |
[/quote]
This is kind of acrappy volt meter from HF....but it comes with ahout a 4" long K-type thermocouple and measures in F and C. Its a decent back up for your good volt meter.
https://m.harborfreight.com/11-function-digital-multimeter-with-audible-continuity-61593.html
They used to sell a $7 volt meter with temp and a TC......and it was accurate to about +/- 2°. I tgink Wal-Mart also sells a VM with temp thermocouple for under $15.
Anything with a K type thermocouple can measure through the dipstick hole. Ray |
Randy in Maine Samba Member
Posted: Wed Jun 20, 2018 1:55 pm Post subject: Re: Temperature Gauge Faulty? |
How do you have this thing timed and what weight of oil are you running?
I have found that both of those variables can really impact oil temps. |
furgo Samba Member
Posted: Wed Jun 20, 2018 2:28 pm Post subject: Re: Temperature Gauge Faulty? |
skunther wrote: |
If you notice, I quoted the original author (akscooter) on my post. It wasn't me who built the homemade dipstick thermometer.
He wrote about it here, so you might want to contact him directly.
What I did myself and showed in my initial pictures was an alternative method, where I tested my VDO-repro dipstick sensor and my gauge, using an automotive multimeter very similar to the one raygreenwood just posted.
Coincidentally, I use it in the same way he says, as a backup multimeter. But it comes handy for temperature measurement, which my good multimeter can't do. The temperature probe it comes with has too short a wire to use it in a dipstick mount, but if you can find other thermocouples to build yourself a sensor, this might be a niftier and more reusable solution than using a digital food thermometer, although not the cheapest. That is,
• Multimeter with temperature display function which accepts standard thermocouple connectors
• Homemade or genuine oil dipstick
• Thermocouple with wire long enough to mount on dipstick _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Wed Jun 20, 2018 2:55 pm Post subject: Re: Temperature Gauge Faulty? |
furgo wrote: |
skunther wrote: |
• Thermocouple with wire long enough to mount on dipstick |
You can buy standard fiberglass insulated K-type thermocouples with the flat pin plug installed...and a welded tip....here...in 6 or 15 foot length for about $25 or less
http://www.tcdirect.com/deptprod.asp?deptid=180/20.
Ray |
Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Fri Jul 27, 2018 12:10 am Post subject: Re: Temperature Gauge Faulty? |
I also use the lasergun to confirm all is good (I get readings around the 85deg when shooting at the case)... specially since my meter goes to full max as soon as I switch on the ignition contact, so disconnected it for now.
Any clues on why the meter would go all the way to the right? faulty sender unit (even though both sender and meter are new and it worked for the first 50km)? _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
furgo Samba Member
Posted: Fri Jul 27, 2018 12:44 am Post subject: Re: Temperature Gauge Faulty? |
Peter - Belgium wrote: |
Any clues on why the meter would go all the way to the right? faulty sender unit (even though both sender and meter are new and it worked for the first 50km)? |
I'd suggest either explaining in more detail what sender setup you've got or posting some pictures.
Without that, it could be anyone's guess. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Fri Jul 27, 2018 1:05 am Post subject: Re: Temperature Gauge Faulty? |
furgo wrote: |
Without that, it could be anyone's guess. |
I have the standard VDO sender which fits in the oil drain plate + a VDO gauge in the dash. wiring etc is all correct since it has worked for a while, then decided not to.
Normally when the meter is all the way out it means it is grounded i thought, but when I measure I seem to measure a 220 Ohm resistance on the senderunit? _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Sun Jul 05, 2020 1:03 pm Post subject: Re: Temperature Gauge Faulty? |
The sump plate VDO sender is variable. @ room temp say 75 degrees it should read 1K ohm. As the temps rise the resistance goes up. I assume you have the 300 degree F gauge and the proper sender. Just to rule things out check the ground from the sender body to the sump plate or the case , should have no resistance . If that's fine then check the connection on the sensor. |
