Tires
Ray Syverson
Ray Syverson is offline
PostPosted: Fri Jun 15, 2018 11:55 am    Post subject: Tires Reply with quote
There's not many tire choices out there for stock 14 inch rims. One of them is the General Grabber AT-2 27 x 8.5 R14, a very nice looking tire. I just ordered some today and was told they are being discontinued. They are being replaced with ATX 27x8.5 R14. Basically the same tire but looking a little different on the sides. Not bad, but maybe not what some would like to see. I was able to get some ordered in from another state to a local Discount Tire Store.
TyWebb
TyWebb is offline
PostPosted: Sat Jun 16, 2018 5:55 pm    Post subject: Re: Tires Reply with quote
I did not know they were being discontinued. Funny, but I ordered a set of the AT-2s through Amazon yesterday. $96 each delivered. Glad I got a set and thanks for letting us know they are not going to be available anymore.
Patrick.
Patrick.
76 Westy Deluxe, Original engine (2.0L, FI, solid), Sage Green
"Don't sell yourself short judge, you're a tremendous slouch."
[email protected]
waugamans@aol.com is offline
PostPosted: Sat Jun 16, 2018 6:56 pm    Post subject: Re: Tires Reply with quote
Did you try Tirerack.Com, thats where I get all my tires, for the Thing up to my modern Hondas.
Wildthings
Wildthings is offline
PostPosted: Tue Jun 19, 2018 11:53 am    Post subject: Re: Tires Reply with quote
Looks like the bit of rounding on the outer tread row might reduce the rubbing a bit.
kubelmann
kubelmann is offline
PostPosted: Tue Jun 19, 2018 4:51 pm    Post subject: Re: Tires Reply with quote
The headlight buckets are quite often the cause of that tire rubbing. This can be solved by removing the headlight assembly and front tire. Look at the tire mark on the headlight bucket. Then using a rubber mallet carefully dent your headlight bucket in the exact place where the paint is damaged. Bingo...
Al Capulco Premium Member
Al Capulco is offline
PostPosted: Tue Jun 19, 2018 11:56 pm    Post subject: Re: Tires Reply with quote
General Grabbers don't rub on a standard height Thing.
kubelmann
PostPosted: Wed Jun 20, 2018 8:48 am    Post subject: Re: Tires Reply with quote
Good to know. Thanks
