orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Fri Jun 15, 2018 1:00 pm Post subject: Rear tail lights |
I replaced the rear tail light housings with aftermarket CIP1 stuff. I am having trouble with the brake lights and side marker lights. The new housings only have one big connector and not two small connectors. I had all the lights working but now the brake lights will not go on when the switch is activated. Has anyone used these and been able to remedy the problem. I thought I could daisy chain the running lights off the license plate wires. This didn’t work for some reason. The wiring diagrams aren’t very useful for my bus since is was manufactured 12/74. It has a mix of 74 and 75 wires. Was supposed to be fuel injection. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
Tcash Samba Member
Posted: Fri Jun 15, 2018 1:49 pm Post subject: Re: Rear tail lights |
You might have blown a fuse.
You should be able to daisy chain off the license plate light.
Make sure the marker lights have a good ground and the bulbs are not blown.
Might be time to break out the test light.
Good luck
Tcash |
Tcash Samba Member
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Fri Jun 15, 2018 2:11 pm Post subject: Re: Rear tail lights |
orangebug60guy wrote: |
I replaced the rear tail light housings with aftermarket CIP1 stuff. I am having trouble with the brake lights and side marker lights. The new housings only have one big connector and not two small connectors. I had all the lights working but now the brake lights will not go on when the switch is activated. Has anyone used these and been able to remedy the problem. I thought I could daisy chain the running lights off the license plate wires. This didn’t work for some reason. The wiring diagrams aren’t very useful for my bus since is was manufactured 12/74. It has a mix of 74 and 75 wires. Was supposed to be fuel injection. |
Picture of old lights
New lights
It looks the the nipples on the bulb aren’t touching the prongs on the new housing.
How do we make this work? Different bulb? _________________ 77 Westy - Cape Cod Sage
LLAP |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Jun 15, 2018 2:14 pm Post subject: Re: Rear tail lights |
I would recommend cleaning up the part of your old housing that holds the bulbs and wires, and install it in the new plastic housing. While the new plastic is nice, the old bulb mounts are better, as you have witnessed.
Also, while you are in there, you might consider "lining" the reflective surfaces on the bulb side of the housing with shiny aluminum duct tape (the real metal stuff). _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Fri Jun 15, 2018 2:51 pm Post subject: Re: Rear tail lights |
That bulb needs to be turned 90° so the pins on the bulb touches each side of the tabs.
Edit: I'm an idiot. I need to read better. Nevermind. _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
