HenrikL Samba Member
Posted: Sat Jun 16, 2018 7:37 am Post subject: Terminal 30 on the push button panel |
I'm installing a new main harness on my 1964 Notch. It was one year since I disconnected the old harness but with the help of a wiring diagram I seem to have found connectors for all wires ... except the big fat wire from the voltage regulator.
The wiring diagram shows it to be connected to the push button panel terminal 30. Is there a spade connector on the push button panel for this wire? It is not very easy to see anything under the dash.
gregson1 Samba Member
Posted: Sat Jun 16, 2018 10:29 am Post subject: Re: Terminal 30 on the push button panel |
No, the push button switch has a single fat wire that goes to the fuse box. Use the fuse box as your 'hub' for the large red wires to the push button switch, voltage regulator and ignition switch. |
Posted: Sat Jun 16, 2018 12:31 pm Post subject: Re: Terminal 30 on the push button panel |
gregson1 wrote: |
Ok, but there are only two spade terminals for that fuse. One is used by the red wire to the push button and the other by the red wire to the steering column. |
Posted: Sat Jun 16, 2018 8:20 pm Post subject: Re: Terminal 30 on the push button panel |
Add a piggyback jumper to that fuse box connector. |
