Carlp336 Samba Member
Posted: Sat Jun 16, 2018 3:46 pm Post subject: Anyone ever have tank outlet nut issue being to shallow? |
i just got my screen and seals.. this wont thread with all the needed bits, only with one seal.
confused with why it seams the outlet nut is shallow? are there different ones?
i was trying to run: seal/screen/tube/seal/nut (no luck)
only wants to thread : tuber/seal/nut
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jun 16, 2018 4:01 pm Post subject: Re: anyone ever have tank outlet nut issue being to shallow? |
Probably after market junk.
Good time to install a reserve tap instead. That way you can shut off fuel flow when removing the engine or replacing all the flex fuel lines. Plus you can use it as designed to keep the last one gallon on hand.... _________________ In Stereo, Where Available! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Jun 17, 2018 10:40 am Post subject: Re: anyone ever have tank outlet nut issue being to shallow? |
I think I've had this wrong. I thought the new screens had a collapsing aluminum base- negating the need for second gasket. Gasket/screen/tube/nut only. _________________
EverettB wrote: |
FU#5 |
Posted: Sun Jun 17, 2018 10:53 am Post subject: Re: anyone ever have tank outlet nut issue being to shallow? |
hitest wrote: |
I think I've had this wrong. I thought the new screens had a collapsing aluminum base- negating the need for second gasket. Gasket/screen/tube/nut only. |
Seems VW went from the former to the latter later on. The aluminum ring of the filter sock does seem to act as a seal due to the softness of the metal it deforms to the tank outlet sealing there. _________________ In Stereo, Where Available! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Sun Jun 17, 2018 7:51 pm Post subject: Re: anyone ever have tank outlet nut issue being to shallow? |
It's been a while, but I think I installed them with the filter sock and only one red seal (not two). I'm pretty sure that I installed the red seal on the sock between the sock and the gas tank.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Mon Jun 18, 2018 8:01 am Post subject: Re: Anyone ever have tank outlet nut issue being to shallow? |
there are several different diagrams with different seal placements for sure .
seams odd though to use a seal between the screen and tank since the aluminum screen base acts as a compression seal. |
hitest Samba Member
Posted: Mon Jun 18, 2018 8:53 am Post subject: Re: anyone ever have tank outlet nut issue being to shallow? |
BulliBill wrote: |
Bill |
Exactly as I have done several times. The tank's threaded outlet pipe is by nature an uneven plane- and requires a gasket. The aluminum ring then crushes easily and allows the outlet pipe adjustment for angle before the final ham-fisted nut goes on.
I suppose a person might get away with filing a tread ring off their nut if it is too tall for the outlet to fully seal... _________________
EverettB wrote: |
FU#5 |
turkis-deluxe Samba Security
Posted: Mon Jun 18, 2018 8:43 pm Post subject: Re: Anyone ever have a nut issue being to shallow? |
I've only ever used one washer on these due to the same issue even on original parts.
I've corrected your title..... Re: Anyone ever have a nut issue being to shallow? |
Posted: Tue Jun 19, 2018 5:29 am Post subject: Re: Anyone ever have a nut issue being to shallow? |
turkis-deluxe wrote: |
i debated how to word it for awhile. |
