ManFromNapa Samba Member
Joined: March 08, 2012 Posts: 184 Location: United States
Posted: Sun Jun 17, 2018 10:30 am Post subject: Spring plate cover with grease fitting |
I was doing some research on adjustable spring plates for my 67 bug. In one video, the guy's spring plate covers had grease fittings in them. I can't decide if this is a good idea, or worthless.
Pros:
I can grease my outer spring plate bushing without taking the cover off.
Eliminate potential squeaks.
Cons:
Can't grease inner bushing.
I've never needed to grease my bushings.
Thoughts? Good idea or waste of time? _________________ North Bay Air Cooled - VW Club in Napa, CA
http://www.northbayaircooled.com/
Check out my band, Thru The Haze
http://www.thruthehazeband.com/ |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Sun Jun 17, 2018 11:57 am Post subject: Re: Spring plate cover with grease fitting |
The bushings are typically installed dry, and do not require lubrication.
Some have replaced the original rubber with urethane, which may need lubrication when installed to not squeak.
This sounds like another level beyond that, and usually would be unnecessary. Perhaps he installed bearings to replace the bushings? Have you taken the cover off to have a look at whats there? |
bluebus86 Banned
Posted: Sun Jun 17, 2018 12:46 pm Post subject: Re: Spring plate cover with grease fitting |
KTPhil wrote: |
Yeah my guess is the same, urethane or some other aftermarket bushing that requires greasing. Dont grease a stock type. many greases might even accelerate degradation.
Bug On In Suspension! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
KTPhil Samba Member
Posted: Sun Jun 17, 2018 1:43 pm Post subject: Re: Spring plate cover with grease fitting |
Yup, no grease... VW recommended talcum (baby) powder for the stock rubber bushings.
But I'm curious what's up with this setup... someone went to a bit of trouble, and must have had a reason... |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Jun 17, 2018 7:36 pm Post subject: Re: Spring plate cover with grease fitting |
I vaguely remember a phase in the 80s where it seemed zerks fittings were added to EVERYTHING. Cutting threads for them was an art. Maybe in the off-road racing world but in a street beetle it would be like an extra nipple- conversational but not at all practical. (That was not supposed to be like a simile) _________________
EverettB wrote: |
FU#5 |
Posted: Mon Jun 18, 2018 3:45 pm Post subject: Re: Spring plate cover with grease fitting |
Thanks everyone. I'm using urethane bushings. I'm not going to install the zerks. If I need to re-lube the urethane, it's not hard. _________________ North Bay Air Cooled - VW Club in Napa, CA
